Tyre size pic for diff ratio
I have bought a vb & p suspension kit and new offset trailing arms from vansteel so far.
The next thing i am saving for now, is the diff. So this might be one of those asked before questions.
I dont want to go the old school 15 inch. As i want a performance tyre on it.
So i was looking at 17 or 18's. My current modern car has 19x235x40 ( pretty sure). But i dont want 19's. So i know i will feel it, bumps that is
Can some people here post a pic of there size/tyre combo so i can see how they fit on the car. Rim style not worry about, just the size.
All this because i am trying to figure out a diff ratio. I know 1st you want around 10 on the stats.
I am using that great spread sheet with all the calculations on it, that i got from these forums.
I am leaning towards 3.7 or 3.9 ATM, but that is using the default type size on the spreadsheet.
i am looking at a ls2 engine and a 200r4 manual auto ( none of these i have bought yet).
Pics aways .
You know how some type/rim combos dont look right. I am trying to look at the sizes and see how it fits in the car. As in what looks crap or not.
Then once i know a size, say 18x245x40 ( the last nuber the most important i asume), i can put that combo in a calculator and pick a right diff ratio.
Like i dont want to buy, say a 3.7 then pick a tyre/rim size and say "should of got the other one).
I already own a car with a ls2 engine in it, so i know how it behaves at whatever rpm.
The spread sheet i got off some member here ( sorry i forgot who) , is a great calculator, type anything it , gearbox, typre size , then it shows speeds in 5mph and what the rpm will be.
Scott
Scott
What Scott is saying. If you stay with a 27" tall tire no matter what diameter or width you choose you should have no problem.What are you looking to do? Do you want the same size front and rear?
Do you want 17s or 18s. If you go with 17s about the only size you'll find that's 27" tall is the 255/50-17. If you go with 18s a 255/45-18 and a 285/40-18 are both about 27" tall.
If you do a search using "17s" and "18s" you will find several threads with lots of pictures.
I hope this helps.
DC
Was looking at maybe 18's back and 17's front.
255/50-17
285/40-18
if i pick the same i think i would go 255-50-17, but was trying to get a 275 or 285 back.
I should of thought of the 27inches to start with... Speadsheet time.
255/50-17
285/40-18
Scott
Scott
