Transmission oil?
Old Jun 25, 2013 | 09:12 PM
jso789's Avatar
jso789
Default Transmission oil?
Hi all,
I noticed there is a whine in my transmission in 1,2,3rd gears. Car is a stock 81 with 4 speed stick. I have heard that some 4 speeds whine in the reduction gears. Is this normal for this transmission or is the gear oil possibly low? How is the oil level checked? and finally if it is low, then what weight oil should I use in it?
Old Jun 26, 2013 | 04:27 AM
terrys6t8roadster's Avatar
terrys6t8roadster
fill plug on passenger side of trans, 80w90 gear oil, drain plug on bottom, maybe a drain and refill is in order. fill to the threads on the side fill. when in lower gears you are putting power through the cluster shaft therefore there will be a slight increase in gear noise. 4th is straight through.
Old Jun 26, 2013 | 05:13 PM
jso789's Avatar
jso789
Thanks for the reply. I should probably change it anyway considering the oil (if any, haven't checked it yet) that is in there is probably from 1981 lol. Anyway should I run conventional or synthetic oil or does it really make a difference?
Old Jun 26, 2013 | 11:41 PM
pappy.72's Avatar
pappy.72
Remember, always remove the fill plug first when doing this. If you can't get it out after you drain the fluid you are stuck.
Old Jun 27, 2013 | 07:11 AM
Marlin's Avatar
Marlin
I prefer Syn but there is a 75w90 semi-syn as well. Wal-mart has the 75w90 semi-syn pretty cheap.
But make sure the car is lifted even (front and rear). If not your trans oil level will be off. Also get a can of brake cleaner to clean off any wet spots and check for leaks.
Old Jun 27, 2013 | 09:13 PM
63split63's Avatar
63split63
Has it always been noisy in 1'2'3 or is it a new noise ? If always it may be an M-22 .
Bill
Old Jun 28, 2013 | 03:33 AM
Garys 68's Avatar
Garys 68
Transmissions with brass synchros like your T10 call for GL-4 gear lube. No, a whine is not normal.
To Transmission oil?
