Starter question
Old Jun 26, 2013 | 10:05 AM
72SLEEPER's Avatar
72SLEEPER
Default Starter question
Hello Guys,
I have a huge problem. I am trying to buy one of those cool high torque lightweight gear reduction starters to put in my 1972 vette with a 383. The original starter from the factory bolted up fine so I assume I will need a staggered bolt set-up. I read on another posting that the Inline bolts will work too by moving it around or something... it was confusing hints the posting. I just want to buy a smaller high torque starter but the right one. Please help!
Steve
Old Jun 26, 2013 | 10:17 AM
SuperBuickGuy's Avatar
SuperBuickGuy
I'm confused, why wouldn't you simply buy whatever mimics what's on your car?
Now you've got me trying to remember if there's a block that allows both patterns - and I'm not remembering one.
that said, there are different starters for the number of teeth on your flywheel either a 153 or a 168 tooth. Obviously the 153 tooth flywheel is smaller than a 168, so the bolt flange will allow the starter to move closer to the center via a 3rd bolt hole in the starter mounting flange.
Odds are, and this IS a guess, you have a 168 tooth flywheel
Old Jun 26, 2013 | 10:28 AM
72SLEEPER's Avatar
72SLEEPER
Yes its a 168. I cant seem to find a mini starter with a staggered bolt pattern. thats why I am here, every shop I call or online store has no idea that they make staggered or inline 168 tooth or 153 tooth...
I would rather buy the staggered bolt cause i know thats what I have
Old Jun 26, 2013 | 10:44 AM
oldalaskaman's Avatar
oldalaskaman
http://www.kmjent.com/cart/3hp-4.4-1...168-tooth.html
one version, there are several others, powermaster , for one
Old Jun 26, 2013 | 10:48 AM
speedreed8's Avatar
speedreed8
I used one of these on my'79 355. its gear reduction, light weight, easily available. its what gm used on their late model 5.7 trucks. works great , staggered bolt pattern. DB electric has some too. good luck. OLDAlak. has a better price!! beat me too it.
http://www.oreillyauto.com/site/c/de...1920&ppt=C0330
Old Jun 26, 2013 | 11:50 AM
72SLEEPER's Avatar
72SLEEPER
Thanks oldalaska thats what i was looking for! buying it now!!!
Old Jun 26, 2013 | 09:57 PM
ChaosPhoenixFix's Avatar
ChaosPhoenixFix
Sounds like you are getting close to turning it over soon!
Old Jun 26, 2013 | 11:47 PM
72SLEEPER's Avatar
72SLEEPER
Yea after the last thread I realized I was really close so I am buying the parts I need to at least hear it purr... some friends are coming over that know nothing about cars and I hoping between some beers and b/sin we can get it done in a day or two still waiting on starter and new salt but I might just get it all done with the old parts and I stall new parts when they come in
Old Jun 26, 2013 | 11:48 PM
72SLEEPER's Avatar
72SLEEPER
Sry I meant alternator
Old Jun 26, 2013 | 11:50 PM
72SLEEPER's Avatar
72SLEEPER
The hardest part is finding parts that are not chrome I want it completely plucked out with small accents like aluminum intake radiator and carb
Old Jun 26, 2013 | 11:55 PM
oldalaskaman
same place has alt's...not chrome
Old Jun 27, 2013 | 07:19 AM
Sunstroked's Avatar
Sunstroked
I know you already bought the staggered starter, but just for next time or in case you're wondering, look on the block where your starter bolts onto. You'll probably see a second drilled and tapped hole in line with the other starter bolt, as well as the staggered drilled and tapped hole. So, yes an inline starter will work as well. I went with an inline on my 72's engine. It's the original block but It too is now a stroker. I have an 11" flywheel (168 tooth). I have no i idea whether 1 style is better than the other, but do know that the summit brand starter I bought fit great and has excellent clearance for headers. Works really good too.
To Starter question
