anyone run 15 x 10 wheels on rear , and what backspace. thinking of putting a pair of drag radials on the back 275-60-15 and was wondering if it will work . summit has a 15 x 10 wheel but has 3.75 backspace, not sure if that will work.
QUOTE=1979C3;1584252995]I have 295-50-15 on 15X10 Torq Thrust Ds w/3.5" backspacing. They don't tuck under the wheel well, but I like the circa-70s look.[/QUOTE]
With the 15X10 and 3.5" backspace I have no rubbing either on the leaf spring or emergency brake mount. Here are some pics:
Reason: Through the links I placed in here for pics of my car, all of my photos are accessible on Photobucket...no bueno.
i run 275-60-15 on 8 inch rims now, if i put the same size drag radial on 10 inch rims it may tuck in to the body tighter. thanks, i used to run l-60-15 in the 70's as big as you could get until the n-50-15 came out
I have Torque Thrust D 15x10 with Mickey Thompson N50's on the rear. The back spacing is 3.75 in. It does stick out a little. I like the look, but some may not. I had to use a 1/4 in. spacer to clear the caliper. The parking brake bracket clears fine.
