Set timing on a 82 and now computer bad?
Old Jun 28, 2013 | 05:38 PM
alconk's Avatar
alconk
Default Set timing on a 82 and now computer bad?
This is the first time I checked the timing on my 82 so it's a new experience for me. Anyway after disconnecting the EST I knew I would get a check engine light, no big deal. But now after reconnecting the EST and clearing the computer I still have the CEL on. My code is a 34 which is a map sensor. I have the factory manual and after following the instruction as far as jumping different pins it says if you still get a 34 then replace the ECM. WTF happened?? If by jumping the pins on the map sensor leads you to a code 33 then replace the map sensor. Well last year I replaced both and fortunately the ECM is still under warranty. My question is why would disconnecting the EST screw something up in the computer? I still thought about replacing the map sensor again just to be safe. What are your thoughts??
Old Jun 28, 2013 | 06:49 PM
Jig A Low's Avatar
Jig A Low
I doubt it had anything to do with setting the timing and more to do with the same voltage spike that burnt out your timing light bulb.
Old Jun 28, 2013 | 10:26 PM
alconk's Avatar
alconk
Computer is fine, for some reason it took out the MAP sensor.
Old Jun 29, 2013 | 11:14 AM
oldalaskaman's Avatar
oldalaskaman
try resetting it again, sometimes just resetting them kicks a code, doesnt mean you have bad parts, just indicates a brain f$%rt, warm it up first.
Old Jun 29, 2013 | 12:26 PM
alconk's Avatar
alconk
Yea I tried that several times. Oh well it's fine now.
Old Jun 30, 2013 | 04:18 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Glad you got squared away, and that it is running good. I have yet to check the timing on mine, as it is also running good, and I just haven't allotted the time to do so......I still haven't put in the Hypertech chip I got last year. Just been busy with everything else......
Old Jun 30, 2013 | 06:55 PM
alconk's Avatar
alconk
I bumped thining up to 8 deg. seems to run pretty good.
Old Jul 1, 2013 | 10:44 AM
Aldo_45030's Avatar
Aldo_45030
Heck if you arent going to use it sell it to me!!!!
Old Jul 1, 2013 | 05:14 PM
74 LS4-454's Avatar
74 LS4-454
I'm still going to use it I just keep forgetting I have it
Its got to be the age Its just got to be the age
Old Jul 1, 2013 | 10:00 PM
Aldo_45030's Avatar
Aldo_45030
I forgot what i posted......
To Set timing on a 82 and now computer bad?
