Replacement master cylinder questions
I have a a couple questions about the particular M/S.
It's one of those:
The first obvious difference is that it has 4 ports rather than the 2 of the one I am replacing. It came with 4 yellow caps but I have blocked the 2 rear ports with correct thread bolts.
First question: When I bench bled it i only did on the 2 ports I am planning to connect the lines to. Should I have bench bled the other 2 ports as well?
Second question: I realised that this is slightly incorrect bore for my power brake equipped vet. It is 1'' bore which is correct for manuals rather than the 1 1/8'' which should be the one for power brakes. I have read that this should lead to a slightly longer travel distance for the pedal. Does anyone know how much longer roughly it should be and whether any other issues might arise?
Be sure to bench bleed the master before installing and adjust the pushrod correctly !
Bleeding the rest of the system I would purchase a power bleeder. Its worth it and I wish I would have when I did mine
I'm not sure those bolts will stop fluid from leaking out the unused ports. Those ports will have a flared seat and it is the flare that seals it not the threads. Plugs should be available at any auto parts store.
