Is there a gauge rebuild guide/write-up out there? I thought I seen one a while back.
My fuel gauge randomly moves about. I did remove all the gauges a while ago to clean em up and replace the bezel and It wasn't working correctly then.
I'm leaning toward the resistor. The tank has been replaced, and to my memory the pump also. I figured i'd go for the easy test/fix first before dropping the tank.
