Throwout Bearing Help - ASAP!!!
Old Jun 26, 2002 | 02:48 PM
lbell101's Avatar
lbell101
Default Throwout Bearing Help - ASAP!!!
It's been a long time since I've changed a throwout bearing.
Please look at these pictures. Is the bearing installed correctly?
Thanks!
[Modified by lbell101, 1:49 PM 6/26/2002]
Old Jun 26, 2002 | 03:04 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Throwout Bearing Help - ASAP!!! (lbell101)
No, it is not. The spring clip ends on the clutch fork should be under the t/o bearing flange.
Old Jun 26, 2002 | 03:07 PM
lbell101's Avatar
lbell101
Default Re: Throwout Bearing Help - ASAP!!! (burners)
That's exactly why I posted this!
Just didn't look right.
Thanks - you just saved me a second tranny pull!
Old Jun 26, 2002 | 03:08 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
No it's not...the ears on the clutch fork should be inside the groove on the bearing :cheers:
Old Jun 26, 2002 | 03:10 PM
kgraumann's Avatar
kgraumann
Does not look installed correctly by the way it looks. The throwout arm/lever needs to fit into the grooves of the bearing itself.
But it just might be just the way the pictures look.
Old Jun 26, 2002 | 03:12 PM
lbell101's Avatar
lbell101
Default Re: Throwout Bearing Help - ASAP!!! (kgraumann)
I can't tell you how glad I am to have posted this.
Thanks guys!
Looks like I've got a date with a hot transmission now.
Old Jun 26, 2002 | 04:44 PM
FeedVaal's Avatar
FeedVaal
Am I too late to tell you it's wrong too?
:D
Old Jun 26, 2002 | 05:06 PM
Fevre's Avatar
Fevre
Default Re: Throwout Bearing Help - ASAP!!! (FeedVaal)
I think it looks right.
Someone has to disagree, right?
:troll :p:
Old Jun 26, 2002 | 05:40 PM
lbell101's Avatar
lbell101
Default Re: Throwout Bearing Help - ASAP!!! (Fevre)
Yep, you guys are too late. The transmission is back in.
Yeeehaw!!!
Still have some of the little stuff to do but I needed a break.
[Modified by lbell101, 4:40 PM 6/26/2002]
Old Jun 27, 2002 | 10:42 AM
71coupe's Avatar
71coupe
You can install it the way you have it in the pic, but it makes a wierd popping & grinding sound when you depress the clutch pedal. The pedal is also super spongy.
Don't ask me how I know this :nono:
Old Jun 27, 2002 | 10:53 AM
lbell101's Avatar
lbell101
Default Re: Throwout Bearing Help - ASAP!!! (71coupe)
That's the sound it was making before I changed it. I think the old one was installed that way when I took it out. I'm not 100% positive of that but I did look at it when I removed it. I'm hoping that it was installed wrong the first time as it gives a reason for the early failure of the bearing.
It doesn't make any noise anymore!
Old Jun 27, 2002 | 10:56 AM
Fevre's Avatar
Fevre
Mine does that and I am pretty sure I put it in correctly. Thing is a 'buddy' told me not to put lubricant on the pressure plate splines or throw out bearing cuz it will get on the disk and cause major slippage. Could this be causing the hard grinding feeling? Funny thing is it is Ok until it gets warm then gets worse and worse.
Old Jun 27, 2002 | 11:02 AM
71coupe's Avatar
71coupe
You'd be suprised the noises you get used to over time. Then, one day, someone rides in you car and says: "Dude, what the f__k is that noise?"
[Modified by 71coupe, 7:04 AM 6/27/2002]
To Throwout Bearing Help - ASAP!!!
