Vacuum Headlight replacement
Old Jun 26, 2002 | 03:04 PM
wcsinx's Avatar
wcsinx
Default Vacuum Headlight replacement
Just curious...
Is there any sort of third party kit that will convert your vacuum powered headlights to electric? And/or has anyone here ever tried to build something like this?
Old Jun 27, 2002 | 01:55 AM
Stevo81's Avatar
Stevo81
Default Re: Vacuum Headlight replacement (wcsinx)
I have thought about it. (Of course I have thought about Julia Roberts, too, but I never did that, either). The wiring would be easy. The only challenging part is designing the mechanism. And getting it in there. Good post, thanks. Hope there are some good replies. :yesnod:
Old Jun 27, 2002 | 10:21 AM
wcsinx's Avatar
wcsinx
Default Re: Vacuum Headlight replacement (Stevo)
I think I'm actually going to try to design them once I get my shark. (prays .. this weekend I think!) Have you thought about any design for them? Maybe we could collaborate? I'm pretty good with getting electric motors to do things. :)
Old Jun 27, 2002 | 10:31 AM
Chucks76's Avatar
Chucks76
There was a guy on here last year that was working on it pretty seriously. Havent heard anything for a while though....
Old Jun 27, 2002 | 10:47 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Vacuum Headlight replacement (Chucks76)
It was 69myway that pulled it off!
Marck
Old Jun 27, 2002 | 10:59 AM
gerry72's Avatar
gerry72
I believe this operation is being considered for a near issue of Junkyard Wars. Seriously, though, once you get the vacuum system working right it is very reliable and simple. I know a lot of folks poo-poo the system but remember, these cars were never intended to last as long as we've kept them on the road and parts do wear out.
I finally got my whole system working the way it did when it left the factory and I don't think I'd ever consider an electro-mechanical conversion of the system.
Old Jun 27, 2002 | 11:22 AM
wcsinx's Avatar
wcsinx
Default Re: Vacuum Headlight replacement (gerry72)
You're probably the first person I've heard actually praise the vacuum system. What's the most common point of failure on them? I know the car I'm probably going to get already has vacuum light issues. The current owner says the lights come up very slowly so he just leaves them up all the time now.
Old Jun 27, 2002 | 12:02 PM
gerry72's Avatar
gerry72
...What's the most common point of failure on them?...
The seals for the actuators, the control valves, the vacuum check valve, the wiperarm relay valve. You also have the override switches and the wiper control solenoid, and of course the hoses, but in most instances you'll find the problems in the first four things. This assumes that Bubba ain't yet got to yer vaccum system fur some custom fixin'.
To Vacuum Headlight replacement
