Rear wheel tilt
Old Jul 2, 2013 | 10:13 AM
melhard's Avatar
melhard
Default Rear wheel tilt
Pass side rear wheel tilts out on my 76 vet. What’s the fix?
Old Jul 2, 2013 | 10:23 AM
billcarson's Avatar
billcarson
check your camber adjusting bolt.they are known to slip.
Old Jul 2, 2013 | 10:50 AM
melhard's Avatar
melhard
Where is the camber adjusting bolt located at.
Old Jul 2, 2013 | 11:15 AM
billcarson's Avatar
billcarson
it is that bolt attached to the eccentric washer just below the spring.
Old Jul 2, 2013 | 12:52 PM
Joelbbvette's Avatar
Joelbbvette
Default Camber Adjsutment
If moving the adjustment to the top inside (pulling the alignment rod to it's shortest position as shown in BillCarsons attached photo) does not allow for the wheel to be vertical, do not bend the rod to get there. Many have done this in the past and it just means buying more parts as it band-aide fix. If this is the case your spring has lost it's arch and it is best to replace that and go for a good alignment.
Good luck.
Joel
Old Jul 2, 2013 | 01:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by melhard
...Where is the camber adjusting bolt located at....
No disrespect, but you should consider taking the car to an alignment shop.
Old Jul 6, 2013 | 09:49 AM
melhard's Avatar
melhard
That corrected my tilt issue. Thanks all
I noticed I have a 1 inch height different from side to side on
the rear of vet. Is there any adjustment to correct that?
To Rear wheel tilt
