74 with a BUBBA carb connector???
Old Jul 3, 2013 | 10:56 AM
74Ken's Avatar
74Ken
Default 74 with a BUBBA carb connector???
Did I just find another bubba on my Q-JET?
The fitting on the bottom of the carb looks like a air-tool fitting. Is this correct?
Anyone have any pics of theirs?
I want to make this as perfect as I can before putting it back on the car.
Ken
Old Jul 3, 2013 | 11:36 AM
scrappy76's Avatar
scrappy76
That is a airline fitting. Should have a fitting on there that will accept the hose that comes from your brake booster.
Old Jul 3, 2013 | 12:06 PM
maverickmk's Avatar
maverickmk
Wow, that's funny. Use what ya' got laying around
Your local auto parts store should have the correct adapter needed there.
Old Jul 3, 2013 | 02:56 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Mine has a hard line from there to the plastic filter(?) that is inline to the brake booster. Rubber hose from the canister to the booster.
Old Jul 3, 2013 | 04:07 PM
Shark Racer's Avatar
Shark Racer
Here's a not great photo of the one on my 78:
Old Jul 3, 2013 | 04:25 PM
74Ken's Avatar
74Ken
That 78 bracket looks like it would work for my 74.
By spreading the bracket over the rear carb mounts the throttle cable would not slide around when pressed, which is my problem right now.
Old Jul 3, 2013 | 05:47 PM
7d8's Avatar
7d8
Not correct, but he might have been on to something there.
Old Jul 3, 2013 | 05:58 PM
7t9l82's Avatar
7t9l82
use compressed air like a blower?
Old Jul 3, 2013 | 06:29 PM
gcusmano74's Avatar
gcusmano74
Ken
The correct throttle bracket is held by a locating pin and both rear carb mounting bolts. A PO cut yours off, for some unknown reason.
Old Jul 3, 2013 | 07:29 PM
74Ken's Avatar
74Ken
Yep, so I have to 'bubba' my own now.
Looking for something with a pin to modify like the one in the picture.
Can't seem to find a replacement bracket. Would be nice to find a shiny new one..lol
Old Jul 3, 2013 | 07:36 PM
Shark Racer
I use the largest drill bit that fits. My car's previous owner likely did not do it, but one of the idiot mechanics she had work on the car likely did.
Old Jul 3, 2013 | 07:42 PM
Peterbuilt's Avatar
Peterbuilt
Here's the bracket on my 74 350 W PB:
Here's an extra bracket:
I don't have the carb to hose fitting.
PM me if you want to buy the bracket.
Old Jul 3, 2013 | 11:35 PM
scottyp99's Avatar
scottyp99
A bead blast or some wire brushing, and some rattle-can spray paint, and it'll look brand-new!
That air tool fitting in the carb is hilarious!
Scott
Old Jul 4, 2013 | 01:03 AM
Shark Racer
Scott
I bead blasted and painted mine.
Old Jul 4, 2013 | 06:52 AM
scottw's Avatar
scottw
The reason Bubba put it there is so you can hook up an air hose on the side of the road to make repairs easier.
Old Jul 4, 2013 | 03:47 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Summit, Jegs, Lokar, eBay all have throttle brackets for the Rochester carb. Just a google away.
cardo0
Old Jul 4, 2013 | 08:31 PM
Shark Racer
cardo0
To 74 with a BUBBA carb connector???
Old Jul 4, 2013 | 11:39 PM
74Ken's Avatar
74Ken
Summit has nothing for a 74, Jegs has some weird looking brackets that I cannot recognize.
I found one on ebay for a "quadra jet 4bbl", but it looks like it may have issues on the one side.
I have decided to purchasing the extra bracket from Pete. As soon as it gets here I will sand it down and paint it before installing it.
Ken
Old Jul 4, 2013 | 11:42 PM
74Ken's Avatar
74Ken
Oh and btw, for some reason the PO moved the correct connector tube onto a secondary manifold port facing up instead of back (as it would on the carb).
So I have the tube, it was just in the wrong place.
I wonder if the vacuum coming from the base of the carb is any different than the one on the manifold.
Ken
Old Jul 5, 2013 | 12:00 AM
Peterbuilt's Avatar
Peterbuilt
Both those ports are manifold vacuum.
