- Why is my Suspension Bouncy?
Guide to diagnose trouble with recommended solutions.
Browse all: Steering and Suspension How-Tos
Rear Bilstein HDs bouncing on 1982 CE
I had the Sports all the way around on my 82, and they simply rode to hard for a "dd" IMO. So I sold them and replaced them with the HD's as you know. In fact if I remember correctly you did the research on the rebound rates for both types.
Now I also have the FE7 on the 82, and the rear spring is replaced with a VBP 340 lb spring, which I had special made for the 74 and ended using on the 82...
I do not experience any bouncing what-so-ever, except if you go over a deep dip on the highway, it will bounce up because of the dip and that is it. I think with the VBP springs at a lower rate, (300, 330) you will experience some type of bounce not matter what you use, (330 less bounce than the 300 IMO) unless you follow the manufacture's recommended shocks for that particular spring. Now different springs from different manufactures may produce different results. I have only used VBP springs on the C3s' that I have owned.
I know we all try to get the optimum ride with the correct springs and shocks, unfortunately it is a trail & error situation, as our riding taste may differ from one another....
I am satisfied with the combo I have now, and I suggest again that the OP just drive his 82 on the road to see if he is satisfied with the ride before he changes anything because of the bounce in a stationary position................................ .......................Tom
In 81/82, if you got the high rate spring it came in a steel variant.
With that said I went with Koni adjustable rebound shocks! Smooth ride and absolutely no bounce because the push down easy but come up slow so you can't get any momentum for the car to bounce. I have the same car as you but a standard 82 not a CE
Without going into all the details on my 78's suspension which was an original sported suspended car, I had the Bilstein HD's with a 360 lbs composite spring and felt that it bounced too much-but nothing like some comments above. Switched to rear sports only (HD's with 550 front coils) and the car drives REALLY nice-not harsh but firm with a VERY comfortable ride. I am often perplexed by those that went with a 330 or 300 LBS composite since I have a 360 composite combo that handles great and rides great as well. So much so that IF i ever need to change my 360 composite (been on the car since 1986), I would consider a 420 spring.
Hope that helps!
I would leave both springs alone or replace them to near FE7 spec.
Much of the aftermarket recommends 300 lbs rear composite springs with 460 front springs for the base suspension cars and 360 rear springs with 550 front springs for the gymkhana suspended cars, in general.
