MSD Blaster 2 coil
Old Jul 6, 2013 | 11:53 AM
Bandit54's Avatar
Bandit54
Default MSD Blaster 2 coil
Anyone using a MSD Blaster coil on a stock point system? I'm having problem with the point pitting and sticking after less then 100 miles. The dwell an timing are dead on everything runs good then it just stops, checked no fire to cap or plugs. Pull cap make sure point will open put cap back on starts up runs OK for a short distance then it stalls. Is the coil compatible with stock point system? I have a problem with the coil resistance and going to change to a different coil. Any feedback would be appreciated.
Engine is a 68 427 with stock point system not a TI.
Last edited by Bandit54; Jul 6, 2013 at 11:55 AM. Reason: Not stating year and engine
Old Jul 6, 2013 | 12:30 PM
7t9l82's Avatar
7t9l82
depending how often the car is driven can effect the points. you may want to convert to electronic ignition, there are many systems that fit in the stock housing. might consider an ignition box too like crane or msd etc
Old Jul 7, 2013 | 08:56 AM
tektrans's Avatar
tektrans
Do you have the coil mounted straight up as MSD recommends? If not that could be your problem.
Old Jul 7, 2013 | 11:23 AM
Bandit54's Avatar
Bandit54
Coil is mounted in the normal mounting position for a 3/2 setup with shielding. My question now after checking voltage and resistance are these numbers correct.
Power to positive terminal on coil:
Key on: 4.35 volts
Key turn to start: 9.9 volts
Engine running: 9.2 volts
When I disconnect the lead wires to the positive terminal on the coil and check voltage I get a reading of:
Key on: 12.5 volts
Key turn to start: 10.3 volts
I have all new wiring in the car, new coil, new points and condenser, cap, and rotor.
Resistance across the coil:
Positive terminal to negative terminal: 00.8
Positive terminal to center terminal: 5.17
Negative terminal to center terminal: 5.17
I have been told correct resistance across terminal should be 1.24 to 1.46 for a point system.
Any and all feedback would be appreciated
Old Jul 7, 2013 | 12:19 PM
oldalaskaman's Avatar
oldalaskaman
put a ballast resister in the power wire
Old Jul 7, 2013 | 12:25 PM
Mike Ward's Avatar
Mike Ward
I'd ask MSD.
Is the stock resistance wire still in place?
Is the points capacitor in good shape?
If it were me, I'd ditch the coil. It's not giving you anything more than a stock unit.
Old Jul 7, 2013 | 01:34 PM
Bandit54's Avatar
Bandit54
The stock resistance wire is still in place, that's not saying its correct it is a new wiring harness.
The points and capacitor are both new, Echlin CS786 and RR175
I agree the coil is in question because of it resistance in neither matches the resistance for points or TI.
That why I'm questing the voltage going to the coil what is the correct voltage with key on, when starting, and after starting and running.
I have talked to MSD in regards to voltage when running their response is as long as its under 9 volts the coil would be OK.
Old Jul 7, 2013 | 02:46 PM
ddawson's Avatar
ddawson
Not sure if this would help but when I replaced my points with the Breakerless system they state only to use with coils of 1.2 to 1.8 ohms. The MSD won't work.
I did find the Accel Coil that every Auto parts store works mine at 1.4 ohms.
The MSD is .7 ohms.
To MSD Blaster 2 coil
