Vette Continues Running With Key Off
Old Jul 6, 2013 | 04:33 PM
tonybyers's Avatar
tonybyers
Default Vette Continues Running With Key Off
Fixing problems caused by Bubba on restoration. Car starts just fine but when key is turned off it continues to run. I can unhook wire from coil marked on coil at Bat+ and it shuts off. I have checked schematics provided by member on this forum and feel I have missed something at key switch connector. Any ideas? Thanks.
Old Jul 6, 2013 | 04:34 PM
'75's Avatar
'75
Try this, start it, turn it off and then unhook the alternator 2 wire plug and see if it dies. I've seen the 2 wires in the alternator plug reversed and cause this.
Old Jul 6, 2013 | 04:59 PM
tonybyers's Avatar
tonybyers
Still kept running.
Old Jul 6, 2013 | 05:23 PM
'75's Avatar
'75
Have you checked the adjustment of the ignition switch on the lower column? Also can you turn it all the way to accessories?
Old Jul 6, 2013 | 08:56 PM
carriljc's Avatar
carriljc
Default When this happened to me it was in the starter solenoid...
I had a heck of a time finding it. I had an intermittent short inside the solenoid wiring and I'd had this electrical draw for ages that I could not locate. Then, suddenly last year, the car would not turn off with the key. I trouble shot the ignition switch, and when the car kept running even I unplugged it, I figured the flaw was elsewhere. By this time I was thinking that this was related to my previously identified amperage draw with the car off. SO, I hooked up my ammeter and started wiggling the wires all over the place......once I got in the starter area it became obvious that something was going on there. I replaced the starter and the solenoid (lifetime warranty) and it's all good.
Old Jul 7, 2013 | 07:44 AM
scottw's Avatar
scottw
Do you have the original ignition system? Only ask because with an MSD ignition you have to put in a diode to break the current.
Old Jul 7, 2013 | 01:25 PM
tonybyers's Avatar
tonybyers
Found issue. Bubba installed toggle switch between ignition and coil. When I cut out all of his splices when redoing wiring I did not tie coil back into ignition system so coil had 12 volts continuously.
Old Jul 7, 2013 | 04:30 PM
scottw's Avatar
scottw
Good find. Gotta love Bubba.
To Vette Continues Running With Key Off
