still got a thump
Old Jul 8, 2013 | 08:15 AM
4 speed's Avatar
4 speed
Default still got a thump
I've added the GM posi lube, check the rear mount looks new not loose, u joint feel tight. but when I let out the clutch when turning, especailly when backing up I hear just a single thump.
yesterday I was down shifting to 2nd while turning left in an intersection and heard it.
also trailing arm mounts look fine.
any thoughts?
thanks!
Old Jul 8, 2013 | 09:37 AM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
any thoughts?
thanks!
ok you added the posi lube, what did you do after you added the lube?
An older mechanic friend had told me years ago that after adding the lube, you need to go to an empty parking area and drive the car at a slow speed 10 to15 mph in complete circles to the left and then to the right about 20 to 25 times each way. His thought was that just adding the lube and driving normal did not distribute the lube properly. But after driving as descibed above, you knew that the lube was evenly distributed throughout the rear assembly. I always did it that way after adding the lube and it worked quite well!!!
Old Jul 8, 2013 | 04:31 PM
4 speed's Avatar
4 speed
I didn't do the figure 8"s but I drove down some nice twisty turny roads weaving back and forth. maybe that wasn't enough.
also checked trans and motor mounts all good.
Old Jul 8, 2013 | 04:33 PM
spinadog's Avatar
spinadog
Being Cap'n Obvious, but did you check your battery tie-down? That battery really moves around if not secured - ask me how I know...
edit: sorry, re-read the post and it sounds like you're at very low/slow speeds...
Old Jul 8, 2013 | 06:26 PM
4 speed's Avatar
4 speed
went up to the school and did 25 figure 8's, seems to have worked, I pulled into and backed out of a few parking spots and no thump
To still got a thump
