M20 or M21
Old Jul 8, 2013 | 10:39 AM
cal camara's Avatar
cal camara
Default M20 or M21
This is a transmission question. In general will a Muncie M21 work with a 3.55 rear end ratio. Normally I believe the 3.55 used a M20 wide ratio and the M21 close ratio was used with lower ratios like the 3.70. This is for a 350 HP motor.
thanks
cal
Old Jul 8, 2013 | 10:48 AM
Brcmpbl's Avatar
Brcmpbl
You're not going to see a huge difference between a 3.55 and. 3.70. A 3.55 with a M21 would be fine.
Old Jul 8, 2013 | 06:19 PM
KenSny's Avatar
KenSny
my 75 L82 came from the General with a Close-ratio 4-speed and a 3.55 posi rear end. Been working just fine for 38 years.
Old Jul 8, 2013 | 07:39 PM
LS4 PILOT's Avatar
LS4 PILOT
my 454 AC equipped...came with M21 an 3:36. factory in74. , with the 2:20 first it is pretty fast in first gear.....LoL. and reverse too !
Old Jul 8, 2013 | 08:44 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Depends on what you want to do. A 7.81 overall first gear with the M-21 is a lot less than a 9.017 that the M-20 would have. It will be pretty long geared in first.
The gear *spread* % drop between the gears is about identical in the first 3 gears. The M-20 has a big drop going into 4th gear. So if you are just running up through the gears the M-20 will walk away from the M-21 with 3.55's in most cases. By the time you grab 4th in the M-21 you're going about 106 mph at 6000 rpm anyway. The M-20 will be running about 91-92 mph at 6000 rpm. The RPM is going to come up a lot quicker with the M-20. That's why it works so well in normal street cruising.
If you're road racing sometimes the M-21 is a better choice because you can get more speed in each gear and keep from having to shift as much. Each gear lasts longer which can make it easier to drive on some courses...unless you don't have enough power to pull the higher gears out of the corner.
If you're drag racing and have 4.56's or 4.88's the M-21 does well because it has a smaller drop into 4th gear percentage wise and helps the engine recover when it's under heavy load.
JIM
Old Jul 9, 2013 | 01:13 AM
20mercury's Avatar
20mercury
Default ditto 76 L82
ditto 76 L82; close ratio M21 and 3.55 rear from the factory
Old Jul 9, 2013 | 10:37 AM
Taijutsu's Avatar
Taijutsu
I have M-21 close ratio w/3:55. I would prefer the M-20s lower first gear. The ratios are too close for a hi tq motor like mine. It is slow off the line.
R
To M20 or M21
