Were C3 alarm systems optional?
Old Jun 27, 2002 | 11:02 AM
68350hp's Avatar
68350hp
Default Were C3 alarm systems optional?
I just wanted to know if they were optional or they all came with an alarm.
Old Jun 27, 2002 | 11:32 AM
sray454's Avatar
sray454
Default Re: Were C3 alarm systems optional? (68350hp)
optional to 71, std equipment from 72 on
Old Jun 27, 2002 | 05:43 PM
68350hp's Avatar
68350hp
Default Re: Were C3 alarm systems optional? (sray454)
The alarm on my '74 doesn't work anymore, is there any way I can fix it?
Old Jun 27, 2002 | 06:05 PM
8T8T2's Avatar
8T8T2
Just put mine back into service this spring. Previous owner removed horn and taped wires. Found out that the drivers side door lock was a little trickie to set so he probably thought it was bad. Installed new high decible horn checked t-top switches, door switches and hood switch. Works like a new one. When set off thou all that happens is the horn blows. No starter lock out on the 80's. So if you see a vette going down the road with the horn beeping its probably been stolen. My wifes 82 does have starter sol. lockout when alarming.
Old Jun 27, 2002 | 10:39 PM
68350hp's Avatar
68350hp
Default Re: Were C3 alarm systems optional? (82zoom)
Is there a way to see If the wire has been cut behind the switch like if the alarm wouldn't turn off and the previous owner cut it? Can I see it from inside the engine bay?
To Were C3 alarm systems optional?
