Electrical Problem
Old Jul 14, 2013 | 12:59 PM
Lacajun's Avatar
Lacajun
Default Electrical Problem
When I turn on the light switch the right turn signal lights up steady and the buzzer comes on. The turn signal operates normally when activated. It appears that the switch is grounding thru the turn signal bulb. I am in the process of removing the instrument panel in order to search wiring. This is on a 78 Pace Car. I am wondering if someone has run into this before and can save me some time and suggest a place to search.
Old Jul 14, 2013 | 01:09 PM
TimAT's Avatar
TimAT
Before you rip the dash apart, check all of the grounds on the front for the headlights and turn signals. Do the easy stuff first.
