Lower cruising RPM?
Old Jul 16, 2013 | 03:31 PM
oldalaskaman's Avatar
oldalaskaman
the 2004r would be pretty much the same low as the 350 and will drive pretty much the same as the 350 in the 1st three gears, the 700r4 is the lower 1st gear one
Old Jul 16, 2013 | 04:14 PM
scottyp99's Avatar
scottyp99
Originally Posted by ChaosPhoenixFix
I like the idea of a 200r4 because it is much easier to put in. How long did it take to do a tranny swap for those of you who have done it?
the 700 isn't that much harder to put in. If you don't have a problem spending an extra 200 bucks on a new cross member and another 150 or so to have your driveshaft shortened, the two swaps become pretty much identical after that. If you've got an honest 400 hp at the crank engine, and 4.10 gears, you'll probably be happier with a 200. Once you get much past 1 horsepower per cubic inch, the engine's powerband becomes narrower, and the wide gear spacing of the 700 may have you shifting into second and falling on your face, because you've dropped out of your powerband. For example, if your rpm drops 2000 rpm when you shift into second now, you may find that it drops 2500 rpm with a 700. With a 200, it may only drop 2250 rpm. The 700 was really meant to be installed behind a motor with a wide, flat torque curve.
Old Jul 16, 2013 | 06:29 PM
ChaosPhoenixFix's Avatar
ChaosPhoenixFix
Well I am going off of numbers my dad gave me before he passed. He said the place he had do the work builds 350's all the time for race cars. They told him it is 435hp and 486ft-lbs. I am not sure if they dyno'd the engine or if that is estimated numbers from similar builds.
The 200 is sounding more and more like the way to go. Simply because I am going to be building on a budget, so cutting costs down is a priority. So starting out $350 cheaper makes the 200 more appealing. However I still want to build it to handle the power. So assuming I can get a good 200r4 from say a turbo GN or along those lines, I plan to put a shift improvement kit in it, but what else would I need to beef up?
Old Jul 16, 2013 | 10:32 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Are there bellhousing pattern issues with using a trans out of a Buick?
Old Jul 16, 2013 | 11:05 PM
iokepakai's Avatar
iokepakai
What's your rear gears? To make the best tranny choice you need to know. 3.08 or 2.78 go 700R4 ....3.55 or 3.73 go 200R4...I went Richmond 6spd with a 3.27 first gear,mated to the 3.08 rear gears makes for quick start offs....Best upgrade for sure.....
Old Jul 17, 2013 | 03:00 PM
ChaosPhoenixFix
I am trying to figure out the gear ratio right now. I think it is either 3.73 or 4.10, however, I was busy at home the last few days, and I am over night at work tonight, so hopefully I can get to it by this weekend and tell you guys for sure. I know at about 65mph my engine is turning about 31-3200 RPM
Old Jul 18, 2013 | 10:14 PM
PaPaPork's Avatar
PaPaPork
those power numbers are pretty big for a street friendly 350... whats your idle?
anyhow, you do not want the 700 since your first gear will be very short with 4tish rear end, plus the driveshaft/crossmember mods, power consumption and weight don't help either.
there is no point of installing a used 2004R if you cant drive the donor car (and by driving I mean pushing it hard and warm not just 400 yards arround the block). 2004R professionaly rebuild is not overly expensive, has warranty, get yourself a shift kit installed and your good to go, you might consider selling your current trans when still in the car...
Old Jul 18, 2013 | 10:18 PM
ChaosPhoenixFix
Idle is about 650-700 once wamed up, IIRC
Old Jul 19, 2013 | 01:15 PM
ChaosPhoenixFix
Tonight I think I am going to check my gear ratio, and inform you guys of my idle RPM. Pending I do not get swamped with stupid stuff...
