Rear window leak on 74
Old Jun 27, 2002 | 05:15 PM
VetteRN's Avatar
VetteRN
Default Rear window leak on 74
Have been looking for the rear window seal for my 74 and can't find one. It is leaking a bit and want to replace. Anyone know where i can find one? Or is it just cauked in?
Old Jun 27, 2002 | 05:29 PM
trw's Avatar
trw
Default Re: Rear window leak on 74 (VetteRN)
Mine was just cauked in. You can either remove it (easier said than done)and do a better job than the factory or use a small bead of silicone in the area outside between the window and the body.
I put a removable window in mine.
Terry
Old Jun 27, 2002 | 05:46 PM
FeedVaal's Avatar
FeedVaal
You can buy butyl tape at a local glass repair store. It takes about 10 feet.
Old Jun 27, 2002 | 06:08 PM
VetteRN's Avatar
VetteRN
Default Re: Rear window leak on 74 (FeedVaal)
Thanx, will give me a project for tomorrow
Old Jun 27, 2002 | 06:12 PM
ORVette's Avatar
ORVette
I bought a kit(from either Zip or Corvette America) that came with the butyl tape and some primer for the surfaces. Also came with a piece of wire for cutting the old seal which I didn't need, mine just sort of fell out one day while I was driving. Took a little time, but really no big deal. Good luck.
ZIP-'02 catalog-page 55-part#ZET-397-$21.95
[Modified by ORVette, 2:14 PM 6/27/2002]
Old Jun 27, 2002 | 06:14 PM
verskel's Avatar
verskel
What about converting it - so it's removeable ??? - just a thought.... :yesnod: :flag
Old Jun 27, 2002 | 06:20 PM
VetteRN's Avatar
VetteRN
Default Re: Rear window leak on 74 (verskel)
What does it take to convert to a removable rear window???????? Sounds like a great idea!
Old Jun 28, 2002 | 06:16 PM
VetteRN's Avatar
VetteRN
Anyone know where I can get a kit (if a kit is made) to make the rear window removable????
1974 Stingray Coup L-82, 4-speed
http://www.villagephotos.com/pubgallery.asp?id_=31326
Old Jun 28, 2002 | 09:35 PM
trw's Avatar
trw
I don't think anyone makes a kit. You could try and get the setup from a corvette graveyard, find someone parting out a 68-72 or buy the pieces on ebay (that's what I did).
I think the total cost was about $200. Best 2 bills I spent on the car.
Besides the window, here are the parts you need.
Hope this helps
Terry
Old Jul 1, 2002 | 11:46 AM
Stewart's74's Avatar
Stewart's74
Default Re: Rear window leak on 74 (ORVette)
My rear window fell out as well :crazy:
Used butyl tape to put it back in...took less than 15 minutes.
To Rear window leak on 74
