1980 Body Bushing height
Old Jul 25, 2013 | 09:21 AM
bodyshopguy's Avatar
bodyshopguy
Navigator
Default 1980 Body Bushing height
Hello, I need some help.
Does anyone have the height measurement of the body bushing of a 1980 Corvette? I purchased a Fixer upper and the previous owner had installed new body bushings. The tire to wheel well gap looks very excessive. If I need to replace the bushings now would be the time before I get to far .
Old Jul 25, 2013 | 09:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Has the rear spring been replaced? My first hunch on your problem would be the spring, not body mounts.
Old Jul 25, 2013 | 10:33 AM
bodyshopguy
Navigator
Hi Mike, Thanks for the reply.
It could be my springs but the car seems to sit even front to rear
It is not a new spring and the original bolts were used.
Old Jul 25, 2013 | 11:16 AM
hugie82's Avatar
hugie82
You have to roller the car back and forth to settle the suspension after jacking it up.
If that's not it, then someone really cranked up on the spring link bushings.
Old Jul 25, 2013 | 01:40 PM
bodyshopguy
Navigator
hi here is the photos of the rear mount. All of the mounts at the same size. If they are the right ones, you guys have put me on the right path.
Thanks again
Old Jul 26, 2013 | 06:45 AM
LS4 PILOT's Avatar
LS4 PILOT
springs and did they use the correct bolts at each end of the spring.
I see C3 sitting wrong all the time, especially in front. to me,
that is way out of wack, but some guy brought a 69 so called restored vette to a local show and it looked like a four wheel drive BLazer...lol.. it sat up maybe 2 to 4 inches at ALL four wheels......looked stupid .....to,me , but the car won best of the show .....it was an awful restoration .......but that's a local show for ya , clowns for judges.
I would think about 27 or 29 inch ride height measured from edge of fender lip to ground would be stock for an 80 would be in the ball park. in the rear, and about 1 inch or so lower in the front. get out the tape measure and take some readings see where you are at.
Old Jul 26, 2013 | 09:18 AM
bodyshopguy
Navigator
Thanks for the input. all 8 body mounts that are installed are the same size I have found that the body is from a earlier year 78-79? than the frame I assume that that should not make a difference. If it is the spring I was going to order the longer bolt kit from Ecklers .
which should drop the rear ? What do you guys think. Thanks again, its great to have people in the know to bounce stuff off
Jeff
Old Jul 26, 2013 | 11:42 AM
qwank's Avatar
qwank
do you have a picture of how the rear spring bolts are installed? I'm seem people install them wrong.
Old Jul 26, 2013 | 11:43 AM
hugie82's Avatar
hugie82
The longer bolt kit will sit it down about 2 inches. Do you have the fiberglass spring or the 7 or 9 leaf spring?
Old Jul 26, 2013 | 12:15 PM
bodyshopguy
Navigator
here are a few photos. 2 inches would make this sit perfect
Old Jul 26, 2013 | 12:16 PM
bodyshopguy
Navigator
looks to be the 9 leaf
To 1980 Body Bushing height
