Door hold open spring replacement
Old Jul 25, 2013 | 04:24 PM
kjbuster1's Avatar
kjbuster1
Default Door hold open spring replacement
Just replaced my door hold open spring following directions from members including Willcox. It was easy and quick. Thanks for the help.
Phil
Old Jul 26, 2013 | 12:49 AM
kjr6306's Avatar
kjr6306
I've tried for 2 days to get mine on. Cannot get the spring in the upper and lower notches at the same time. I wonder if something is broken on my hinge???
Old Jul 26, 2013 | 09:34 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Where did you get the spring... some on the market are not cut correct and they will hit the hinge before you can get the slot in place.
Willcox
Here is a link on how to install.
http://willcoxcorvette.com/product_i...ducts_id=26946
Here is a video.
Door Hinge S-Spring Installation
Old Jul 26, 2013 | 12:11 PM
kjr6306's Avatar
kjr6306
Watched the video several times.....looks pretty simple with the door off the hinges. Not much room to work with when they are on the car. Anyhow, I put the hinge in position and get the top end into both slots, push it all the way down and try to line up the bottom slot but it will not slide in to the bottom slot without coming out of the upper slot. Will try again tonight....
Old Jul 26, 2013 | 12:24 PM
0Willcox Corvette
Former Vendor
Make sure the edge of the spring isn't hitting the hinge.. if it is, then you can cut it off.
You'll know because you won't be able to slide the spring in place to twist or knock upwards. I believe the I gave the measurement of the spring to check with in the video. If it's loner than the measurement, cut it off and try again.
Willcox
Old Jul 26, 2013 | 12:43 PM
kjr6306's Avatar
kjr6306
Yup the measurement is in the video. Thanks for the help. Will report back later.
Old Jul 26, 2013 | 09:11 PM
kjbuster1's Avatar
kjbuster1
Default Door spring replacement
Are you using a tool shaped like a bent screwdriver to install? I have two photos I copied off the web that are very helpful ( I thought they were from Willcox ) Anyhow, I could email or fax them to you. I can't find where I got them from.
Phil
Old Jul 26, 2013 | 09:53 PM
0Willcox Corvette
Former Vendor
Phil
If they are mine... feel free to post them here. I have thousands of pictures and lose track of them.
To Door hold open spring replacement
