1980 Corvette Differntial Fill plug
Old Jul 27, 2013 | 02:14 PM
JDavila's Avatar
JDavila
Default 1980 Corvette Differntial Fill plug
HI Guys,
New to the forum. Love the tips. One question. Just drained and filled the gear oil in the differential. Trying to put fill plug back in. How tight should it be? I've tightened it as much as I can but there are threads still showing. Should it thread all the way in and be flush with the housing? Or is it OK that there are threads still showing. Thanks!
Old Jul 27, 2013 | 02:34 PM
MIKE80's Avatar
MIKE80
Threads showing is fine, just make sure it's snug and check to make sure it isn't leaking after you go for a short drive.
Old Jul 27, 2013 | 03:07 PM
JDavila's Avatar
JDavila
Awesome, thanks for the quick response!
Old Jul 28, 2013 | 10:24 AM
scottyp99's Avatar
scottyp99
Didn't you take a good look at it before you removed it? Keep that in mind for the future. Sometimes I will take a photo.
Scott
Old Jul 28, 2013 | 10:54 AM
BKarol's Avatar
BKarol
20 ft-lbs according to my books.
No torque wrench? then see post #2
Old Jul 28, 2013 | 02:47 PM
JDavila's Avatar
JDavila
Thanks for all the info, guys. Lesson learned!! Will definitely take photos before I take things apart!
Best part is, no more noise from differential!
To 1980 Corvette Differntial Fill plug
