Cleaning solution for rusted parts
Then evaporust and/or electrolysis to remove the rust without eating the good metal.
Evaporust is just molasse on steroid, let is dry and you'll see get sugary sticky paste.
Evaporust is kinda expensive (at least he in Canada), so I wire brush the obvious and then let it finish the work as it can only absord a certain amount of rust.
Then, phosphoric acid will neutralize whatever remains.
Before painting I heat the part with a propane torch, as metal dilate and closes its pores you can see humidity oozing out of the part.
1 part molasses and 2 parts water.
Let the parts soak for a week in a plastic drum.
Like new.
Super cheap and amazing if you have never seen it before.
.I Did so more search and found your point confirmed.
Got to learn new stuff everyday.
Thanks for the tip.
I have tried both. The electrolysis black crud brushes off very easily with no sand mess. I just use a wire brush. For bigger pieces, I put a brush on my electric drill to save some elbow grease. Sometimes it will even wipe off with a rag. You are not removing rust - it is gone. When I tried sand blasting on rusted material, I thought it was much more tedious.
Even though I have a 55 gallon electrolysis vat, thanks to this thread, I just got some evaporust to use on small parts (nuts and bolts). Electrolysis will work, but it would be easier not to wire up each part. However for big parts, you can't beat the price of 55 gallons of electrolysis "juice" - about $10. If you purchased that much evaporust using the quart price, it would be almost $2,000. Also, the $10 solution never wears out.
Not sure where to buy raw chemicals like phosphoric acid and such in Ontario, and neither Home Depot nor Lowes have Etch & Prep up here, or anything marketted for that purpose it seems.
PS: I am looking to clean up some of my pitted floor of my 1980 before I glass over it and put the new carpet in
prep.
Learned this in the late 60s, automated production paint lines ran parts thru a phosphoric acid bath, then rinsed and baked it, then spray painted parts and baked again.
Professionally you can buy OSPHO at a auto paint wholesaler, but more expensive.
If you're in dairy country, you may be able to get this or similar wherever farmers shop and it's pretty cheap and phosphoric.
Monarch CIP Acid or
Dairyland Milkstone Remover & Acid Rinse
(even at Truevalue Hardware)
If you need very little, then Limeaway is a weaker solution.
HCL works just be prepared for flash rust. Perhaps a liquid neutralizer and a phosphoric cleaner to seal it up after would be effective and timely
Wash it off while still wet and the metal will be absolutely clean as new, but will flash rust if not neutralized while wet.
Or
Leave it on and let it dry. It turns leaves a blackish coating which will not rust for approx a year here.
Marketed as a rust converter and paint prep.
I've often done both with the last application left to dry. Here is a pic as a rust converter. Frame sprayed with a weed sprayer.
I managed to find one of the rust products at Canadian Tire, cleaned up and cupped brushed the floors with CLR then rinsed and used the retail stuff to soak over night to get out the last of the deep pits. I cannot believe that the floor actually came clean! Even after running the grinder and heavy wire wheel over it it was still heavily pitted, even rusted through on one spot on each side.
I'd still like to find some phosphoric acid for next time though, sounds like it is the only good option.
The hardest part is cleaning things you cannot dunk and soak. I used heavy shop paper towels and laid them out perfectly flat and soaked them with the stuff, making sure to work out any air bubbles. I cannot think of any way to work with it on anything other than a fairly level surface though. Maybe a gel of some kind?
Overall, I find electrolysis about the easiest way to clean off rust on anything you can hang into a pail. Hang it in the pail, hook the charger up and come back tomorrow to change to the next part.
cardo0
. As if I just wet it. I'm trying the full immersion now....
I use apple cider vinegar full strength to remove rust from light to heavy. I put 3 gallons in a plastic pale and drop in the goods as needed. Heavy rust takes a week or 2 and will clean out rust like it's been sand blasted. It leaves a black film that need to be scrubbed off.
It's safe and easily disposed.
