Engine cutting out
Old Jul 28, 2013 | 09:14 PM
1978vett's Avatar
1978vett
Default Engine cutting out
First weekend with the 78,, took it out yesterday and drove a least 3 hours non stop, it ran great... We went out again today and it was running fine,, on the way home I noticed that it was cutting out under load.. It would smooth out when I let up on it.. After getting home I went back out and it started fine and idles fine,, just cuts out under load.. Any advise will be great.. Thanks
Old Jul 28, 2013 | 10:50 PM
GRipp 73's Avatar
GRipp 73
Was this the first time you tried to run the Corvette hard? So on the first three hour non stop trip you never pushed it to see if it would break up? Only today?
Just trying to see if this is reoccurring, or something that just started today.
Easiest thing to do is probably pull the plugs and see what they look like and check the wires back to the distributor. See if they have any cracks or if any of the wires are too close to the exhaust manifold. I may be way off, but it is something to check with any "new to you vehicle" anyway.
Good luck.
Old Jul 28, 2013 | 10:59 PM
my 76 ray's Avatar
my 76 ray
It could also be a clogged fuel filter. They're cheap and pretty easy to replace.
Old Jul 28, 2013 | 11:06 PM
1978vett's Avatar
1978vett
Yes, it just started today and I wasn;t running it real hard .., I pulled 2 plugs and 1 of them looked really bad,, not oil fouled just really carboned up.. This car only has 41000 miles on it, so it hasn't been driven alot.. I'm hoping a good tune up, will be what it needs..
Old Jul 28, 2013 | 11:19 PM
1978vett's Avatar
1978vett
I was looking for the fuel filter in poor lighting,, didn't see it.. Is it near the carb ??
Old Jul 29, 2013 | 06:50 AM
scottw's Avatar
scottw
If there is a fuel filter, it would be on the line from the fuel pump to the carb.
Mine did not have one when I bought it but when I changed to a Holley Carb, I did an inline filter. Mine just had the mesh screen going into the carb when I first got it.
Old Jul 29, 2013 | 07:00 AM
1978vett's Avatar
1978vett
Ok, I will look today with better light,, also where is the ignition coil and what should the plugs be gapped at ?
Old Jul 29, 2013 | 08:41 AM
78SilverCam's Avatar
78SilverCam
I had a similar experience earlier this year.
Were you able to restart the engine after cutting out? If not, you could try to splash some gas directly into the carb to start it up - does it maintain idle?
If the above is true - here is a guess.
You probably stored the car for the winter and didn't use fuel stabilizer. The fuel over the months formed a varnish like finish at some parts of the fuel system and when you put it under load - the engine is 'choked off' and cuts out.
Is all the above technically correct? Probably not. I'm not a guru like some folks on here. But I did have the same problem and splashed premium fuel into the carb to get it going, filled the tank with premium fuel and it's my theory the new fuel 'cleaned out' the fuel line.
Car doesn't stall out anymore. But all the radiator hoses need to be replaced...from one promblem to another...
Old Jul 29, 2013 | 08:56 AM
BKbroiler's Avatar
BKbroiler
If the car is unmodified, the fuel filter is in the inlet to the carburetor. Remove the fuel line at the carb and then remove the fuel nut - approx. 1" wrench size.
The coil is mounted to the top of the distributor cap.
Plugs should be gapped at .045".
Old Jul 29, 2013 | 12:31 PM
1978vett's Avatar
1978vett
The engine didn't completly stall out, it just cut out when I would accerate and when I let off of it , it was ok.. It does start good and idles fine ..
Old Jul 29, 2013 | 12:52 PM
Peterbuilt's Avatar
Peterbuilt
Default I'll take a guess...
Have you checked the accelerator pump?
With the engine off and the air cleaner removed and the choke open, move the throttle and see if you get two steady streams of fuek shooting into the carb.
Old Jul 29, 2013 | 02:39 PM
my 76 ray's Avatar
my 76 ray
It's best to use a flare nut wrench on the fitting that is on the fuel line.
http://www.sears.com/craftsman-5-pc-...p-00942013000P
OK now my original comment that it's cheap is no longer true.
A regular wrench or even a large crescent wrench will work on the nut that holds the filter in the carb. Also hold the nut that holds the filter in the carb while loosening the flare nut on the fuel line otherwise you can bend and kink the line.
Old Jul 29, 2013 | 03:15 PM
1978vett's Avatar
1978vett
I checked the accelerator pump and it is good... I did notice what looked like a condensor fastened to the intake ,, the distributor is near it .. The wire to it wasn't connected to anything ... It was that way when I got the car does anyone know what it is and where it should be connected ?? Thanks
Old Jul 29, 2013 | 05:01 PM
BKbroiler's Avatar
BKbroiler
The condenser type thing is your tach filter. It should plug into your distributor cap, where it says "TACH". But, it has nothing to do with your engine problem. I'd say you have a bad fuel pump or fuel filter.
Old Jul 29, 2013 | 05:51 PM
1978vett's Avatar
1978vett
There is already something plugged into my distributor where it says tach and it is working... It isn't a points type distributor..
Old Jul 29, 2013 | 06:35 PM
BKarol's Avatar
BKarol
Does it look like this?
http://www.ecklerscorvette.com/asset...ette/46137.jpg
If so, then the previous owner just bypassed the filter. The tach is working so I would leave it alone. I havent had a filter in 10 yrs.
Old Jul 29, 2013 | 07:05 PM
1978vett's Avatar
1978vett
Yes, it looks exactly like that..,there isn't aany place to plug it in, there is already something pluged in where is says tach.. What does a tach filter do?
To Engine cutting out
Old Jul 29, 2013 | 07:09 PM
1978vett's Avatar
1978vett
My tach works fine, the only thing I noticed was when I shut the engine of the tach needle doesn't drop to zero..
Old Jul 30, 2013 | 12:32 AM
my 76 ray's Avatar
my 76 ray
One wire from the tach filter will plug into the distributor cap where it says tach and the wire that is currently plugged into the distributor cap where it says tach will plug into the other end of the tach filter.
Old Jul 30, 2013 | 06:43 AM
BKarol's Avatar
BKarol
and the needle will stay at the rpm it was when you turned the key off.
If you always want it at zero when you leave the car, turn the key without starting and it should drop to zero.
