1980 - plastic connector on A/C compressor - Diode???
Old Jun 28, 2002 | 03:25 PM
vettesite's Avatar
vettesite
Default 1980 - plastic connector on A/C compressor - Diode???
The plastic connector broke. Went to the parts store and found one that has s diode in it. I don't know if the old one has one or not.
Does a 1980 need the diode?
If so, why?
Will it hurt the A/C compressor if I use the connector with the diode?
Thanks.
[Modified by vettesite, 3:44 PM 6/28/2002]
Old Jun 28, 2002 | 04:21 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: 1980 - plastic connector on A/C compressor - Diode??? (vettesite)
There's a diode on the wipermotor connector, not on the AC pump I think. At least I never saw it... are you sure?
Marck
[Modified by Twinnie, 2:22 PM 6/28/2002]
Old Jun 28, 2002 | 04:34 PM
ksems's Avatar
ksems
Default Re: 1980 - plastic connector on A/C compressor - Diode??? (Twinnie)
the 81 has it.....dont know about the 80.
Went i went to get a replacement they had both kinds on the shelf...
the 81 uses the diode connector
good luck
Kevin
Old Jun 28, 2002 | 04:36 PM
Marc01's Avatar
Marc01
St. Jude Contributor
I'm not sure what year they started putting the diode there. I don't have one on my '78, but ksems has it in his '81.
See this thread:
http://forums.corvetteforum.com/zerothread?id=326295
I think it is there so that when the compressor kicks on it doesn't feedback into the system (I think).
Old Jun 28, 2002 | 04:38 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: 1980 - plastic connector on A/C compressor - Diode??? (Marc78)
I checked *removed the AC stuff) my compressor has the diode too :)
Never noticed that before, then again I don't care for airconditioning. ;)
Marck
Old Jun 28, 2002 | 04:57 PM
vettesite's Avatar
vettesite
Thanks for the info guys! I hope someone with an 80 can check and let me know if the connector has the diode.
Marc78: Thanks, I read that post and it does not contain the answer, it was more about the compressor connector. That's the post that got me wondering about the diode.
Twinnie: I like my A/C. :yesnod:
Old Jun 28, 2002 | 05:00 PM
Twin_Turbo's Avatar
Twin_Turbo
I have no use for it.. when it's cold & rainy here it's useless and when it's warm (3 days a year) I drive with the tops off..and worst of all.. it costs power (& clutters the engine compartment... have no space for AC)
Marck
kgraumann's Avatar
kgraumann
I have an 80 and can check right fast, but I'm not sure what your talking about.
Old Jun 28, 2002 | 05:43 PM
vettesite's Avatar
vettesite
Default Re: 1980 - plastic connector on A/C compressor - Diode??? (kgraumann)
kgraumann:
I mean the small black plastic connector on the top of the A/C compressor that has a black and a green wire coming out of it. This plastic connector may or may not have a small diode between the wires. Mine does not and I want to know if this is correct and if it will hurt anything if I install a connector with a diode. Thanks for checking.
:cheers:
Old Jun 28, 2002 | 05:51 PM
kgraumann's Avatar
kgraumann
Mine does not have the Diode.
Old Jun 28, 2002 | 06:13 PM
vettesite's Avatar
vettesite
Thanks for checking kgraumann!!! :cheers:
GM must have started using the diode on the 1981s. It probably has something to do with the ECM (computer)????.
My question now is, will it hurt anything if I install a connector with the diode? My guess is that it won't but I'd rather be safe than sorry.
Old Jun 28, 2002 | 06:18 PM
Twin_Turbo's Avatar
Twin_Turbo
Yeah, probably the diaode has to do w/ the AC on signal sent to the ECM to up the idle RPM :)
Old Jun 29, 2002 | 02:45 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
If you are talking about the two wires that connect to the compressor (in one connector), I don't see any diode.
Hope that helps.
To 1980 - plastic connector on A/C compressor - Diode???
