My new pilot bushing that came with my NAPA clutch kit doesn't fit. It looks like the right size but it is too tight of a fit to get in with a rubber mallet. I froze it overnight and put a little grease on it but it feels like it will not go in without excessive force. I searched around a little and it seems this is a common problem. Any suggestions? The inside diameter is good, it fits right around the transmission input shaft. I've heard stories of smashing it into place causing problems where the input shaft no longer fits.
Should I sand the outside a bit? Or spray it with canned air to freeze it better?
Have you measured them? They look the same to me. Mine took more than a rubber mallet but not excessive force. Maybe clean up both surfaces with emery cloth to smooth things up a bit.
Pilot bushings are a light interference fit. They are usually .0005 to .001 larger in diameter than the opening in the crank. A bushing driver is preferred but a socket close to the outside diameter can be used as a driver.
If you can put one in with a rubber mallet, something's wrong.
We have a driver for doing this and a rubber mallet is not what we hammer it in with.
I had the EXACT problem with my NAPA kit, I had to whack it in pretty hard with a block of wood.
I also spent 3 days trying to get the input shaft to seat into the bushing. I used the 'pack the hole with grease and use a bolt to pressure it out' removal method.....I used the same bolt, smeared in valve grinding compound, to open up the new bushing enough to take the input shaft.
I got it in when I switched to a metal hammer. It destroyed the old socket I used as a buffer but the bushing only has superficial scratches. The alignment tool still fits just fine so I expect the transmission shaft will also. Thanks guys.
Why do we replace pilot bushings anyway? I don't understand how a solid brass piece can fail. The old one I pulled out looks just fine, even through my clutch was ground to dust.
We replace them because they do wear.... Anytime you have friction you'll have wear. Front bearings in the transmission will wear, the input shaft will wobble and the pilot will get eaten up pretty quick. When you have one that is out of round you'll know it usually... you'll start picking up a vibration in the drive line.
They are actually made from what is called Oilite which means it is a oil impregnated bushing...
Not all pilot bushings are created equal!! If a magnet sticks to the bushing it's a cheapy..Check out Autogear for quality pilot bushings..Don't know about a NAPA one...
Last one I installed, I used a driver borrowed from AutoZone. No worries about inside diameter changing (top of the bushing "mushrooming" as result of whacking it with a hammer.
I've used an old socket too, but the proper tool is usually the best way to go...and ya can't beat FREE tool rental!
I have the roller bearing pilot in one of my Vettes. From feedback on this and other forums, it may have been a mistake. So far, so good, for 20k miles. However, in deference to the bearing, I make an effort to pop the shifter into neutral and release the clutch, say at a stoplight, for example. That way I'm minimizing wear on the pilot to momentary use during engine starts and gear changes. So far so good, but I'll go with the majority recommendation and us the solid oil impregnated bushing next time.
