push rod question
Old Jul 30, 2013 | 08:04 PM
lamoore0888's Avatar
lamoore0888
Default push rod question
I have one bent push rod in my 350 (1980 vette). My friend says I can use another push rod that is maybe 1/32 shorter until my new push rod of the right length comes in the mail.
Is that true? Or will that somehow damage the engine?
Thanks,
Larry
Old Jul 30, 2013 | 08:06 PM
BKbroiler's Avatar
BKbroiler
It should work as long as you adjust that valve properly.
Old Jul 30, 2013 | 08:15 PM
TimAT's Avatar
TimAT
Stock pushrods should nearly be a local auto parts store item. If you have roller rockers or something that takes an odd length then you should order one.
AS Bk noted- a little longer or shorter, as long as it's adjusted properly, will be a non issue.
Old Jul 30, 2013 | 09:28 PM
lamoore0888
Thank you BKbroiler. I appreciate the tip.
Old Jul 30, 2013 | 09:29 PM
lamoore0888
Thanks Tim.
To push rod question
