Definition of original engine?
Old Jun 28, 2002 | 08:29 PM
Shark Driver's Avatar
Shark Driver
Default Definition of original engine?
I looked at a Corvette and it had the original block verified by the stamp. But the heads were not original not even from a corvette but made by Chevrolet. so can the owner say that it has the original engine?
Thank you, Rachel :confused:
Old Jun 28, 2002 | 08:37 PM
63Banshee's Avatar
63Banshee
From: WANTED: '68 rear valance with b/u light assemblies IM, e-mail, or PM me here. Thanks!
Default Re: Definition of original engine? (Shark Driver)
He can say it, but he's wrong.
Old Jun 28, 2002 | 08:54 PM
Robert N's Avatar
Robert N
Default Re: Definition of original engine? (63Banshee)
Original engine is the exact one that came with the car, including all major engine parts.
Old Jun 28, 2002 | 10:07 PM
SharkAttack's Avatar
SharkAttack
It could be said that the car has the original block, but not the original engine. Also, I have heard of people having aftermarket blocks stamped just to say it is a "numbers matching engine" (deceitful). You have to ask all the right questions.
Old Jun 28, 2002 | 11:11 PM
subboz's Avatar
subboz
Default Re: Definition of original engine? (wireless guy)
I would tend to disagree with this statement. As long as the code on the block and heads match the appropriate year and model as the car in question. However I believe in 74-75-76 around there they started to match engine to vin number on vetttes. How is a NCRS judge gonna know if your 1970 block casting and heads that match the vin engine code didnt come in your 12,456 build but came out of the 13,345 build car?
Old Jun 29, 2002 | 02:32 AM
Rockn-Roll's Avatar
Rockn-Roll
Original means that it came out of the factory like that. You can pull the engine, rebuild it with the same parts and it will still be "Original". However, if you install a new seal or use some sealant then it will just be Stock (as long as you use "stock" sealant and seals. However, your question is better asked at the http://www.corvettemuseum.com or at the National Corvette Society web page...where ever it is. They have specific rules about what "original" means.
Old Jun 29, 2002 | 05:12 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Definition of original engine? (Rockn-Roll)
The original engine, to most people, means the original engine block, regardless of whether it's been rebuilt, etc. Just because someone has replaced the heads, or the valve covers, or carburetor, etc, that doesn't alter the fact that these parts are on the original block. If you want to use the term "total matching numbers", then all of the parts ON the engine that are date coded or have certain casting numbers should "match" those used in your year of car, and the dates on those parts should preceed the assembly date of your car and your motor.
Chevy started stamping VIN's on motors in late 1960, not in 74, 75, 76. So, your engine will have several identifying features. It will have the correct casting number used for your year Corvette. It will have a casting date preceeding the assembly of your car, and it will have 2 sets of numbers stamped on the pad in the front of the passengers cylinder head. Those 2 sets of numbers are the VIN derivitive, and the assembly date/suffix. Hope this helps :) Chuck
Old Jun 29, 2002 | 05:50 AM
mrvette's Avatar
mrvette
Chuck is totally corect in his previous reply there, BUT.....
all of that NCRS matching # stuff can be duplicated, not all that hard either....so that even NCRS most pickey guy can't tell....
in fact I heard that some vette organization was backing off from alot of that **** matching numbers crap on account of it's too easily duplicated, and they been proven wrong.....too many times....
I would not give any money extra just for any matching numbers....none whatsoever....
of course nore would I detract for non original parts either, in fact, depending on just what was done, you might want to add.....as in it's not something you have to worry about in the near enough future....
things like water pumps, or any other engine accessory...trannies, rear differentials, etc....especially brakes....
GENE
To Definition of original engine?
