Sharkbite install
Old Aug 2, 2013 | 08:50 PM
ddawson's Avatar
ddawson
Default Sharkbite install
I'm stumped.
After you mount the shock bracket the strut brace won't line up because the bolt is in the way.
Anyone have the same issue?
I was told the stock sway bar was not going to be an issue as well, but I think I can find a way to use the stock bracket for the swaybar.
The kit assumes you will not be using the stock setup.
