Diagnose a vibration.
Old Aug 3, 2013 | 07:08 AM
timgman's Avatar
timgman
Default Diagnose a vibration.
After searching through the forum on vibration, I'm slightly educated..
so I thught I'd throw this theory on my problem out here and get some advise.
My 77 has a fairly serious vibration at speeds above 40 mph.
If I'm within ' the vibrating speed range (say 65 mph) and I put it in neutral it stops immediately. If I rev the engine in neutral or at a stop there's not excessive vibration.
So, should I start looking at u joints?
ie: is a vibration that goes away in "N" a driveline / U joint issue?
Thanks to you all for helping me keep this thing running all these years.
timgman's Avatar
timgman
Also, From waht I've read a bad engine tune could cause this.. Is that a possibility?
Old Aug 3, 2013 | 11:40 AM
gcusmano74's Avatar
gcusmano74
I would imagine you have a broken accessory bracket. Look carefully at the PS, alternator, AC mounts, etc.
Old Aug 3, 2013 | 02:56 PM
timgman's Avatar
timgman
Will do. Thanks for a pointer bud!
Old Aug 3, 2013 | 03:02 PM
MelWff's Avatar
MelWff
It's engine related. check the harmonic damper to make sure the outter ring hasnt shifted. check the engine fan and fan clutch for anything loose.
To Diagnose a vibration.
