New c3 corvette and build!
So im getting a black corvette with restored black interior. All new american racing rims and new tires. New rear axle and whole new suspension, audio system also.
Im getting it for dirt cheap from a guy I know because he wants some dune buggy for 3600 so thats what he is gonna take for the corvette from me! He wanted 6k
Gives me alot of money left over. It only has 60k miles on it and its an l48 so I know Im gonna want more power.
Im going to order this weiland 142 kit but my question is. What else will I need? Every part. This car can sit for a month if need be because I just finished my 18psi turbo build on my other car
here is the link!
http://www.summitracing.com/parts/wn...ette/year/1976
I get it the 11th! Cant wait! going to St. Louis to pick it up
Also already have an exhaust and headers. With a 262 cam and 2101 performer intake manifold, felpro gasket top end kit, new oem rocker arms, new timing chain, lifters, and a recurve kit. All of this will be going on it at the same time.
Except intake manifold lol. So let me know!
What im guessing Ill need is an
air filter
air filter scoop for it
boost gauge
fuel pressure gauge
However, DIALED IN PERFECTLY is the key. Keep the timing very moderate, and never let it go lean. That 262 cam is not the greatest, duration looks OK, but the 110 lobe separation should be 112-114 for these little blowers. Also, that 650 is going to be too small. Some say that you almost can't over carb. a blower, but I would run at least a 750. Your 87 octane is not gonna cut it. An 8.5:1 motor with 5psi boost has an effective compression ratio of about 11.4:1. Remember above about detonation?
Do your homework. These mini blowers can be fun and reliable, and CAN work on some basic motors, but you have to know your limits.
So run a 750. Got It
What gas shoukd I run? I have access to everything as I run 110 race gas on turbo daily sometimes
I would have a shop do the tune and jet the carb. I will tell them I want it very rich.
Also add and an a/f ratio gauge too
Its a black on bLack 76 with new interior, seats, suspension, tires, power steering, rear axle
I cant wait to out on the sc and exhaust!
Im getting it for a steal fyi just want to know how much.
I was building an n/a engine on my last corvette
Any thoughts on the power steering issue? And will it be fine for a 3 hour drive? With breaks every hour.
And with the kind of questions you're asking it is obvious you're not an expert at this kind of thing. If your tuner makes a mistake and you grenade the motor, then where are you? SOL, because the tuner surely isn't going to give you a new one.
Crawl, walk, then run.
Pete
Pete
Use the search function on this forum to find power steering problems. Learn all you can. The average car mechanic probably hasn't seen a p/s system like that on an older Corvette so you can't expect to drive in just any garage and find somebody who can find the parts and fix it.
Good luck,
Pete
It got new tires today
due to my last fiasco.Its restored interior, 9/10 exterior black on black with 60k miles for 3600
its a long story how I got it that cheap lol
