AC/heater removal
![](/forums/images/ranks/3k-4k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Ok been meaning to start this project for awhile. I use my car for light cruising and drag racing and the fuse is pulled for the ac/heater anyway and most of the AC stuff is long gone, no coolant lines hooked up. I want to remove the AC/heater and I'll make a plate to block off the firewall. I need the room under the hood anyway for the dedicated nitrous fuel system. I have been researching the removal and it seems it's going to be a PITA. Still maybe not too bad because I'm not trying to replace anything.
The engine is still in the car and I'd appreciate any advice before I start because I'm not sure if it's more than a week job and I should leave it for when I park the car. I'm hoping I won't have to tear apart the interior or can leave that part for another time.
![](/forums/images/ranks/5k-6k.gif)
You'll need to pull the right dash panel. And it's going to take some finesse to get the A/C box off the front of the firewall, but it's doable. I removed the factory A/C and installed a Vintage Air system in the 77 I had.
Cool thx, just found some good info on how to do it. Seems sometimes I can't find the information I need until I ask. 4 bolts 3 inside & 1 under the hood and pry it apart.
I think there are 4 under the hood.. 1 of those can be easily gotten to from beneath the car, next to the heater hoses, 2 are easily seen from the top and one you are going to have to feel for on the other side of the blower.
