Batt drain invisible ?
Old Jun 29, 2002 | 02:22 AM
Stevo81's Avatar
Stevo81
Default Batt drain invisible ?
Found out there was a bad battery drain. Hooked meter in series to battery. Pulled fuses til one made needle drop. Fuse is "ctsy clk" and supplies light in the mirror, power antenna, door locks, clock (don't think I have one), seat belt/ign key buzzer and the horn.
So I am thinking "All those items produce light or noise...if I put the fuse in and out, I will hear or see something..." Negative. So now will try to isolate them individually. It's good I have no life and lots of free time. :confused:
Old Jun 29, 2002 | 07:15 AM
mrvette's Avatar
mrvette
Default Re: Batt drain invisible ? (Stevo)
check any socket for especially a missing bulb, allowing the socket to fall apart enough to short out.....pull the lighter plug also, in that circuit, theyseem to be the main two failure points...
