Steering damper range
Old Aug 5, 2013 | 11:42 AM
rafalc's Avatar
rafalc
Default Steering damper range
Im putting together my steering components and was just wondering.... how many steering wheel turns should the damper allow in each direction starting from dead center? Is it an even number each way? In my case it seems like one way is about a quarter turn less than in the other.
Old Aug 5, 2013 | 09:33 PM
rafalc's Avatar
rafalc
Come ooooon nobody? Someone please go out to your garage, get into your PS c3 and turn the wheel from dead center to the max left and right. How many steering wheel turns does it allow you going from the center to the end of each side?
Old Aug 5, 2013 | 11:11 PM
Jim Shea's Avatar
Jim Shea
The steering gear allows 1.8 turns from exact center to full lock in either direction.
Jim
Old Aug 5, 2013 | 11:16 PM
rafalc's Avatar
rafalc
Jim
oohh so its the steering gear thats the limiter and not the damper...
Thanks Jim
Old Aug 6, 2013 | 06:50 AM
Jim Shea's Avatar
Jim Shea
There are also steering stops cast into the steering arms. General Motors designed them so both the steering gear travel and the steering arm stops would "bottom out' at the same time. This way both systems shared the load and were not overstressed by having to take all of the loads at full travel.
Jim
To Steering damper range
