Strut rods are bent
Old Aug 7, 2013 | 04:06 PM
ndmick's Avatar
ndmick
Default Strut rods are bent
I`m back messin with my cars(been doing a house remodel).While under the back of my 1971 small block .Noticed both sides strut rods are bent .I`ve done some searches and I guess some alignment shops bend these . Car seems to handle good no tire wear bushings aren`t great but not wore out. I suppose I should replace ? any suggestions,I just drive this car around once and a while but I like it rite .Should I use Adjustable SmartStruts.
Old Aug 7, 2013 | 04:40 PM
Mooser's Avatar
Mooser
If everything is ok (alignment etc), drive it.
Someday when it's an issue or your bored or have a sever case of the whileImatit's, fix them.
As to going adjustable or not, up to you. One way changes the length of the strut, the other moves the pivot point. GM left it with the offset washers for a long time.
Either way will be fine. pick one that fits your needs, pocketbook and personal opinion
M
Old Aug 7, 2013 | 04:45 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ndmick
...Should I use Adjustable SmartStruts...
Can't see much in your pics, but I agree with Mooser. If alignment is good now, there is no need to replacement them right away.
You do not need smart struts.
Old Aug 7, 2013 | 05:11 PM
Mike Ward's Avatar
Mike Ward
There's nothing smart about smart struts.
Old Jan 25, 2015 | 02:51 PM
ndmick's Avatar
ndmick
back at it again.1971 small block would they have bent these if they are offset trailing arms?camber is good .toe is not.Bad shake at 12 and 6 ,nothing 3-9.Going to do the back end in the next 2 months ,springs ,TA,strut rods.
Old Jan 25, 2015 | 02:54 PM
ndmick's Avatar
ndmick
camber adjustment bolt is all the way.did the front end last year ,just finished borgeson steering upgrade.
Old Jan 25, 2015 | 02:55 PM
ndmick's Avatar
ndmick
sitting on ground drivers side
Old Jan 25, 2015 | 03:21 PM
LS4 PILOT's Avatar
LS4 PILOT
I would definitely be replacing them from what I see in this pics. That's bowed alot .
You have a nice car ...why drive around like that......buy what you need , put it back right.
I 'm just very **** about such stuff . Do as you wish .....
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Alignment shops have definitely been known to bend struts rather than align the rear the proper way. It seems to me that this procedure just masks the real problem. I personally would replace the struts with new bushings when you get a chance.
Old Jan 25, 2015 | 03:23 PM
mikep3's Avatar
mikep3
Looks like someone used the struts as lifting points to jack the car.
I put a Borgeson unit in 25K miles ago, big change, but was better after I rebuilt the rear bushings. The standard strut rods are cheap about $100 for the pair with new bushings. Get a lower shock bolt removal tool for 20 bucks.
Old Jan 25, 2015 | 03:40 PM
ndmick's Avatar
ndmick
its all going to be replaced.I`m just doing some research.before I buy.strut rods? (adjustable or not)(heim joints or not)..Rebuilt Trailing arms..or not... composite spring or not (yes I believe)...any help or suggestions are welcome and thanks in advance.
Old Jan 25, 2015 | 03:55 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
JMHO, but if an alignment shop had to bend the strut rods that much to get the rear end in spec, with the standard adjustment bolt at the extreme setting, then I would go with an adjustable set, either rubber bushed or heim joints, your choice.
If you are going with a fiberglass spring, you will need to upgrade to compatible shocks.
Old Jan 25, 2015 | 04:08 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by c69vete
JMHO, but if an alignment shop had to bend the strut rods that much to get the rear end in spec, with the standard adjustment bolt at the extreme setting..
..........there's any underlying issues that needs to be fixed.
Adjustable struts would just be a band-aid in these circumstances. I'm betting the diff yokes are shot.
Old Jan 25, 2015 | 04:36 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
And I bet you are right. He did say that there was play at the 12-6 positions.
Old Jan 25, 2015 | 04:54 PM
ndmick's Avatar
ndmick
Whats the best way for me to check the yokes?can I do it with everything still together?when I check at 12 and 6 seems like the movement is in the spindle. Grabbing the 1/2 shafts no movement?
Old Jan 25, 2015 | 08:22 PM
Mooser's Avatar
Mooser
Looking at the pic it seems like yours could still be even shorter so something else must be out, I wonder if the arm is twisted. Maybe check with a straight edge, car sitting level. Up near the pivot and then back near the 1/2 shaft. Both should be the same angle.
Bending the rods for alignment seems to have been more common than you'd think, either by shops who didn't understand the offset washer system, ones that couldn't get the adjuster to move, ones that didn't care about the adjuster or ones that ran out of adjustment and still needed more.
That said I've never seen a set bent that far but if they were trying to align it with underlying problems (bent trailing arms) it's hard to say what all would be done.
Both of me rear arms were bent just behind where the taper ends.
At first I thought curb hits but once they were cleaned both had the same amount of bend and you could see "press" marks where they held and pushed. Definitely done on purpose.
I suspected that back in the day someone tweaked them for wider tires.
Old Jan 25, 2015 | 08:52 PM
70LQ4's Avatar
70LQ4
Back in the Day 2 post Hydraulic Lifts were common at most Repair Shops and especially Transmission Shops. One post lifted by the front lower control Arms and the rear post had a Saddle that lifted by the Axle Tubes. Most Mechanics really didn't give a crap . It bent the arms too bad, hate workin on Corvettes anyway.
To Strut rods are bent
Old Jan 25, 2015 | 09:02 PM
Mike Ward's Avatar
Mike Ward
Have a helper move the wheel at 6/12 o'clock while you watch the yoke for movement.
Old Jan 25, 2015 | 10:06 PM
1974ta's Avatar
1974ta
Default Strut Rods
Keep it stock.
You will be very pleasantly surprised at how nice the vette rides and handles when set up correctly.
Bill
Old Jan 25, 2015 | 10:18 PM
briankeery's Avatar
briankeery
Darrell, go with the heim-jointed rods, and a good set of Bilsteins to offset the spring rate of the new mono shock. I went with HD's instead of sports as I'm not tracking the car. My spring was rated at 360 lbs......car rides a lot better than before.
