considering getting a c3, what upgrades?
So someone educate me, what are the good years, and what mods make a difference?
Thanks in advance!
Thanks in advance!
I strengthened my stock frame and went with VBP Performance Plus full suspension with modern 275/40 ZR17 tires, 385 stroker, T56 6 speed, and 370 rear. There are many different options for brakes.
Thanks in advance!
If the basics are there (brakes, suspension and engine) then pick the body you like. I always had a preference for the gill slits on the 68 and 69. Some the egg crates of later years and some the lines with the rubber bumpers.
Let us know some of your likes and dislike and what you plan to do with the car and you can get a more targeted reply.
I think you would want to drive both the earlier and later c3 before making a decision on which to buy.... I like the earlier style more vs the bubble window but the earlier style is full of blind spots which drives some people crazy. The later interiors are a bit more roomy... if I remember correctly the early 68-70? Interiors are the most cramped.
There's a lot you can do to make the C3s handle better. Check out this forum, there's a lot of mod information.
The '68s and '69s don't have the flares on the fenders the later models have. Not a deal killer but it does make them more prone to rock chips. The '68s have a lot of one of a kind parts.
Popular mods include:
DeWitts Aluminum Radiators w/ dual Spal electric fans
Spreader Bars
Upgraded springs and shocks
Better tires and wheels
Overdrive transmissions
Auto Meter Gauges
C4/C5/C6 seat swaps
Removable rear window conversion for '73s to '77s
Higher output alternators
LS engines
If you live in an area where emissions is a big deal, an earlier C3 might be a better choice. Catalytic converters started with '75s.
DC
the one thing I hate about any plastic bumper car is the constant warpage of the silly 'urethane'? whatever these plastics are today....so to correct that, you need do a LOT of body work, runs prices up to the moon, or your T&E....take your pick....
So, I got lucky and bought an old show car, with rectangular tail lights from a '68 Olds.....and a totally gorgeous burgundy paint job that was about ~12 years old, this was in Maryland....
moved here in '97, and so the paint suffered....still does, suffice to say I not a painter, not even laytex on a wall.....
BUT, as to mechanical improvements, there is nothing stock about my car from wheels through roof.....NOTHING....
short form....'89 vette wheels, cheap, 275/50/17 rear, NItto only, 255/50/17 front....limited the steering radius, but still tighter than my '87 was, 2.5" VBP adapters....O ring stainless calipers, no springs, dot 5 fluid, and Hydroboost, aluminum master cyl...., 460 front springs, 360 Plastic from VBP once again, and Bilstein sports shocks, entire rear suspension was rebuilt up north 18 years ago....rear ~1/2" sway bar, front is about an inch, once again a cross support between shock towers....which is the second best handling improvement to the car, first being my own RACK & PINION install, done with my welder buddy assistance be ME, winter 01-02, using only two universal joints..on the input shaft....
Now to the engine, '89 roller block 4 bolt factory mains, 350 of course, #113 L98 aluminum heads.....but you note the L98 is DONE , and a highly modified LT1 induction with up/over air cleaners....Cam is a dead stock L98 with double roller Cloys chain set.... headers of course, 200 4r auto instead of the muncie, have a Hurst shift rod topped with a REAL 8 ball.....you just not cool unless you have a 8 ball on your shifter.....
I added power windows, I"m lazy, I stuck with the 336 gearset....
Dual Spal electric fans, behind a stock '89F body radiator, single row aluminum, I use a HUGE engine oil cooler for trans cooler....serp drive and have the a/c working with R134, the obvious interior changes are on the sites below, along with the obvious exterior changes....
