HELP!! ...Pulley alignment problems!
Old Jun 29, 2002 | 06:53 PM
rainman69's Avatar
rainman69
Default HELP!! ...Pulley alignment problems!
All, my dear Corvette has decided that she no longer wants misaligned pulleys...
I have no idea what pulleys are on there now, but I'm pretty sure that they aren't right, as the water pump pulley only has two grooves and I have a 350/350 with AC...shouldn't it have 3 grooves?
What are the part numbers on all the pulleys that I am supposed to have? My engine has started chewing up belts...
Old Jun 29, 2002 | 07:01 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: HELP!! ...Pulley alignment problems! (rainman69)
Look in the AIM, both in the optional engine section for the 350/350, and in the AC section. Pullies vary with other options...power steering for one. The part number of your pulley/pulleys should be listed in the AIM. With the part numbers, you could probably CHECK with GM to see if they have them. If not, it's the aftermarket vendors, or used parts vendors. Chuck
Old Jun 29, 2002 | 07:04 PM
rainman69's Avatar
rainman69
Default Re: HELP!! ...Pulley alignment problems! (Chuck Gongloff)
My AIM is in the mail...I can't look in it yet...
I have 350/350, AC, power steering...that and the alternator and (now gone) AIR pump. Is there anyone that can look it up in the AIM for me today? Maybe scan a page or two?
Thanks! :smash:
To HELP!! ...Pulley alignment problems!
