Power take off with automatic
Old Jun 30, 2002 | 12:29 AM
Dwayne 76's Avatar
Dwayne 76
Default Power take off with automatic
Okay, so I have a 'stage II' shift kit, question is; on the advise of 1Bad69, I put the tranny in 1st, then when it gets to about 4000, I shift it to 2nd, but when I do that, the thing dosn't shift 'till it's up to about 5200. So obviously, I need to shift later then what I'm doing but if I do that the tach needle starts bouncing, which looks cool, but very unnerving at the same time. Any thoughts, am I playing with trouble by trying to shift the car in this fashion, or should I just let the auto do what it was built to do?
TIA
Dwayne
Old Jun 30, 2002 | 05:35 AM
Shark Racer's Avatar
Shark Racer
Default Re: Power take off with automatic (Dwayne 76)
If your valvebody shifts at 5200, and you give it full throttle, it'll probably shift at full throttle regardless.
How is it on mild throttle operation? When I rev mine up w/ about half throttle, maybe less, and shift anywhere past 3k, it usually shifts instantly.
-Steve
Old Jun 30, 2002 | 10:10 AM
Dwayne 76's Avatar
Dwayne 76
Default Re: Power take off with automatic (Pacin'California)
Mid throttle? Sorry dude, what do you mean by that. I am VERY new to the world of car optimizing. :yesnod:
Old Jun 30, 2002 | 10:31 AM
Larry B.'s Avatar
Larry B.
You need to disable or at least readjust the "detent" switch. Othwerwise it will not shift up until redline or close to it.
To Power take off with automatic
