heater core
Old Aug 16, 2013 | 09:40 PM
redvetteman81's Avatar
redvetteman81
Default heater core
I'm getting ready to change the heater core, any suggestion on who to buy if from, I don't want to do this again because of a failed part. Thanks guys in advance.
Old Aug 16, 2013 | 11:07 PM
Peterbuilt's Avatar
Peterbuilt
I'm sure others will post their favorite vendor. No matter who you buy it from take it to a radiator shop and have them pressure test it and have them double check the welds where the tubes connect to the core.
Old Aug 17, 2013 | 08:56 AM
markdonc's Avatar
markdonc
I have a 74 coupe no air The old one came out in 20 minutes from under the hood, the new one from NAPA took about 2 hrs to put back in . I guess it was "NOT EXACTLY" like in the Hertz comercial.
Old Aug 17, 2013 | 10:37 AM
renovator's Avatar
renovator
When I pulled the heater core out of my 70 I took it to a well established local rad shop and they replaced the "center core" only with an American made unit with the same exact dimensions and re fitted the side plates and tested. Went back in like original. He explained that there were only 2 manufacturers left that he knew of, one in PA somewhere and one in Tampa. It cost me $95.00 total.
To heater core
