Vacuum brake booster unit- Need some help
Old Aug 18, 2013 | 12:15 PM
Argiris70's Avatar
Argiris70
Default Vacuum brake booster unit- Need some help
Recently I replaced the manual brakes with a vacuum brake booster unit and master cylinder combo. The feeling when I push the brakes pedal is good but then when I release it does not return or returns very slowly.
Any ideas what the problem is?
Old Aug 18, 2013 | 12:18 PM
oledave60's Avatar
oledave60
There is a round return spring on the shaft that the pedal pivots on. Mine was broken and a new one fixed the problem.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
Old Aug 21, 2013 | 03:49 AM
Argiris70's Avatar
Argiris70
Thank you for your reply. I will check the spring . I hope the problem is there.
To Vacuum brake booster unit- Need some help
