Stock '75 drag racing advice?
Old Aug 18, 2013 | 01:16 PM
Alexs75's Avatar
Alexs75
5th Gear
Default Stock '75 drag racing advice?
Does anybody have any good tips on how to play with the suspention on a c3 manual corvette to get it off the line? thanks
Old Aug 18, 2013 | 02:54 PM
7t9l82's Avatar
7t9l82
i have no idea what kind of power you are putting out so its hard to say.
we used to put spring clamps on both ends of the spring to help and a good rear shock preferably a 50/50 type and 90/10 fronts and remove the front sway bar. BUT that is strictly for drag racing and under NO circumstances drive it that way on the street, not even just to and from the track. again i have no idea what kind of power you are making AND all of this may be unnecessary . good luck
Old Aug 18, 2013 | 03:07 PM
Alexs75's Avatar
Alexs75
5th Gear
Im putting out about 350 hp, everything in the rear end is stock. the rear shocks are even weak i do believe, as in they should be replaced. but it does tire hop every once in a while. what are those spring clamps you mentioned? ive never heard of them
Old Aug 18, 2013 | 03:11 PM
7t9l82's Avatar
7t9l82
i have even used stainless steel hose clamps to clamp the leafs together and make the spring stiffer. at that power level put some stiff shocks on the rear you might try clamping the spring on both ends
Old Aug 18, 2013 | 03:22 PM
Alexs75's Avatar
Alexs75
5th Gear
Ok thanks for the advice ill probably start with new shocks then go from there. any recommendations on a brand? ive seen bilstien is a well know shock
Old Aug 19, 2013 | 10:30 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Stiff rear spring or add leaves to it....GOOD adjustable rear shocks. QA-1's work great. Make sure it doesn't squat so much that it hits snubbers and lets halfshafts go overcenter. Might need to extend snubbers some.
90/10 front shocks and a set of Moroso or similar front springs will make it launch like crazy with good tires.
Make sure everything in rear is in good shape if it's going to have sticky tires.
JIM
Old Aug 19, 2013 | 04:22 PM
Alexs75's Avatar
Alexs75
5th Gear
I did a little research and I see that QA-1s are a good shock so im looking into that. Do you know if the "single adjustable" shock is worth looking into also?
Old Aug 19, 2013 | 08:43 PM
427Hotrod's Avatar
427Hotrod
I've got singles on mine.
JIM
To Stock '75 drag racing advice?
