1978 need help with parts recognition
Old Aug 20, 2013 | 12:34 PM
Machina15's Avatar
Machina15
Cruising
Default 1978 need help with parts recognition
Hello, I have bit of a problem, with custom parts that have been installed by previous owner. Long story short, 3 weeks ago I bought 78 C3, and now it's somewhere in the middle of Atlantic Ocean.
Thing is, I don't know what parts might have been put in that car (besides new exhaust headers). Thanks to forum, I know at least this car should have L48 engine, but I can't tell if this is factory engine (shouldn't engine block be blue?). Other than that I don't know anything about what's inside. It's heck of annoying if you don't know what's inside of your car.
BTW is there a way to tell a diffrence (without dyno, or driving) from 383 stroker or L48?
Old Aug 20, 2013 | 01:06 PM
Mike Ward's Avatar
Mike Ward
I'll tell you very honestly that I don't see one engine component or accessory that is stock. No way of telling what you've got unless you disassemble it.
I'd be concerned about an immediate overheating problem given that the radiator shroud is missing and someone has downgraded the car with a flex fan.
Old Aug 20, 2013 | 01:18 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Machina15
Stock 79 L-48 below; 78 would be nearly identical.
Old Aug 20, 2013 | 01:25 PM
Roco71's Avatar
Roco71
Wow... don't ya just love hot rodding
Old Aug 21, 2013 | 04:18 AM
Machina15's Avatar
Machina15
Cruising
Thx for the advice about heating. So looks like I will have to disassamble it (trip to dyno would be needed too).
Old Aug 21, 2013 | 07:01 AM
TedH's Avatar
TedH
You can see the engine pad just forward of the passenger side cylinder head. Clean the (rust?) from the surface and compare it to the number on the driver's door pillar. If it matches, original block at least.
I'd address the spark plug wires/routing. there is nothing keeping them off of the headers.
Old Aug 21, 2013 | 10:22 AM
Ely's Avatar
Ely
EZ Mike
Your stock pic. of the '79 L48 has (2) air intakes to the air filter.
I thought that was an indication of the L82.
Old Aug 21, 2013 | 10:47 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by Ely
EZ Mike
Might be true for 78 L-82 but there's no real indication the OP's car is/was an L-82.
Old Aug 21, 2013 | 12:09 PM
Crash80's Avatar
Crash80
EZ Mike
My 80 L-48 has two intakes to the air filter. I think the 78 was the same, no matter which engine was in there.
Old Aug 21, 2013 | 12:49 PM
Rich's'78's Avatar
Rich's'78
My original '78 L-48 had a single snorkel. I thought only the L-82s had the dual snorkels.
Old Aug 21, 2013 | 01:19 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Rich's'78
...My original '78 L-48 had a single snorkel...
I thought so, but wasn't certain. IIRC, they went to dual snorkels for all engines beginning with the 79s and added 10hp to the L-48 numbers (real or imagined) as part of the hype.
Old Aug 21, 2013 | 02:47 PM
BKarol's Avatar
BKarol
This is correct in 1978. Dual for L82 and one for L48
Original engine from the factory was painted blue.
Off the stamp pad that tedh mentions, the suffix on the top line will tell you what the block was. Under will be the partial vin.
Internals could have been changed. Without taking it apart you will never know.
Old Aug 21, 2013 | 03:08 PM
Machina15's Avatar
Machina15
Cruising
So with German custom, I will go with cc350. As soon as I get my hand on the car(about a week or so), I'm gonna check about block itself.
I have one more question( I saw it's very delicate matter ), what engine oil I should use? Also I should say that it's very hard to get oils that are used in US (I have really hard time finding mopar 5w20 to my wrangler - there are maybe 2 shops in my hometown that have it).
I also saw Royal Purple - is it better than mopar oil?
Old Aug 22, 2013 | 05:06 PM
BKarol's Avatar
BKarol
Just a FYI. Noticed this in the 1978 Chassis service manual and the owners manual:
NOTE: SAE 5w-20w oils are not recommended for sustained high-speed driving.
I would suggest asking the seller what he had been using and continue to use a quality oil. The sticky at the top of the page will give you some brand names.
I do not remember Mopar Oil being discussed on this forum. Good luck.
Old Aug 23, 2013 | 08:56 AM
Easy Mike's Avatar
Easy Mike
MoPar and Royal Purple are trade names. Royal Purple is synthetic; not sure whether the Mopar is synthetic or dino.
To be honest, oil use for you will depend on what you can obtain locally. I would think your local auto parts store would have something available off the shelf comparable to anything you could purchase elsewhere.
Old Aug 23, 2013 | 01:09 PM
Crash80's Avatar
Crash80
My bad.
To 1978 need help with parts recognition
