11" vs 10.5" Flywheel
Old Aug 21, 2013 | 05:21 PM
FlyLS6's Avatar
FlyLS6
Default 11" vs 10.5" Flywheel
From what I'm reading the factory high performance 454s came with flywheel 3993827 11" flywheel. (According to Fisher re crate engines, anyway)
But there was also a 10.5" high performance flywheel 3963537 for 454 applications.
Has anyone who started out with the 11", gone to a 10.5" configuration, and what kind of results did you have?
By results I'm thinking about streetability/ reliability/ performance (due to less rotating mass). Maybe a "splitting hairs" type of question, but just curious.
Old Aug 21, 2013 | 05:42 PM
Scott Marzahl's Avatar
Scott Marzahl
The 11” clutch has more clutch surface area, therefore it should handle more power. Remember if you go with a 10.5 (153 tooth) you are going to need a new bellhousing, and new starter as well. An important thing to think about is how much do you want it to weigh? A steel billet 11” can be had in anything from 10, 12, 18, 29, 30, 35 and 40 pounds. The weight of your car, power band and gearing will help you determine what weight would work for you. Example is a 3.08 rear would want a heavier flywheel, with 3.70 of 4.11s you could use a 18 pound flywheel on the street. A high quality, steel billet flywheel is a must for high RPM performance applications.
Old Aug 21, 2013 | 07:40 PM
jnb5101's Avatar
jnb5101
i always heard that the Hp engines used a 10.5" flywheel due to it's lower inertia and therefore faster reving. any truth to this?
Old Aug 21, 2013 | 07:59 PM
Scott Marzahl
Basic physics would say that is not 100 % true. For the same weight flywheel yes, but the basic formula is Inertia=Mr2. The biggest variable here is the mass, the radius difference in the formula is either 5.25" squared or 5.5" squared. When you can vary the weight from 12 pounds to 40 pounds, and convert to mass, that's the big factor.
Old Aug 21, 2013 | 08:11 PM
MIKE80's Avatar
MIKE80
I run a Fidanza aluminum 11" Flywheel that weighs 13 lbs. on my stroker engine with about 500 hp, and it revs up quick.
Old Aug 21, 2013 | 10:19 PM
FlyLS6's Avatar
FlyLS6
Default Flywheel
Others would probably know better, but I think L88s and/or Zl1s came with 10.5".
I was just going by the info in Fisher's book. He has a section that lists a multitude of factory high performance part number listings, and the LS6/7 crate information he had specified the 11" I quoted. Under a section on flywheels, he listed them individually, including the 10.5" I referenced.
I'm not planning a change, but don't mind a little extra knowledge.
I would think that the 11" reference above would certainly be a high performance unit, as it was specified for the LS7 application in addition to the LS6.
Old Aug 21, 2013 | 10:33 PM
Scott Marzahl
The L88 flywheel is 10.5 BUT it weighs 15 pounds too.
To 11" vs 10.5" Flywheel
