Anniversary 427 install questions
Old Aug 22, 2013 | 03:12 PM
01hotrod's Avatar
01hotrod
Default Anniversary 427 install questions
We got our Anniversary 427 Aluminum installed and running last week. To baseline it, I wanted to see if any of you guys had done this swap and more specifically if anyone dyno'd theirs. I have some initial numbers with little run time on the engine.(approx 3hrs)
Looking to see something to compare by. I think it's a little low at 338hp to the tires. The GM Performance rep that I spoke with told me that the engineering department wouldn't proceed with a "claim" unless the engine had 5000mi or the appropriate run time on it. We're just concerned that 40-60hp won't magically show up during the remainder of the break-in time. Any real evidence is appreciated.
Old Aug 22, 2013 | 05:14 PM
gkull's Avatar
gkull
I had to look this up to comment. Yes, a broke in motor will gain some HP. Not a lot. I haven't run a dyno comparison to give you a number.
I don't follow your figures? 338 RWHP could be right up around the claimed 430 hp due to power losses of auto tranny. You hear all kinds of loss figures comparing crank hp to RWHP. Lets just call it 15% for a manual tranny and 20% for an auto.
This motor is a very mild, no frills, low compression, low valve lift. Lets say that it makes 440 crank when broke in. Minus 15% That give you something like 374 RWHP possible. Poor timing and tune will drop this number down. Restrictive exhaust??????
This is not a hot rod like the modern Vette LS7 with 505 HP.
Based on an exotic aluminum block, the ZL1 offered only the best components from the L88 engine including a high compression piston, high flow aluminum heads and intake, and a bombproof bottom end. To celebrate the 50th anniversary of the Chevrolet big-block, GM Performance Parts has brought back a modern version of the ZL1 for your chance to relive musclecar history. The Anniversary Edition 427 starts with the ZL1 aluminum block using the tooling that helped create this legend in 1969. The block offers a full-strength structure, thick deck surfaces and 4-bolt mains. Building on that foundation, the short block contains a forged steel crank, forged steel rods, and forged aluminum pistons for a 10.1:1 final compression ratio. Aluminum oval-port heads and matching high-flow aluminum oval-port intake are paired with an 870-cfm carburetor. The camshaft is a hydraulic roller with valve lift numbers of .510" on the intake and .540" on the exhaust. We even added 1.7:1 aluminum roller rockers. Like the original ZL1, the Anniversary 427 comes grossly underrated at 430 horsepower. Once you purchase an Anniversary 427 big-block crate engine, you enter a very exclusive club because only 427 of these engines will ever be produced. A special owner's kit includes official Anniversary 427 emblems to place on your car, as well as an engine data plaque and certificate of authenticity that share a matching serial number with the valve covers. Only 427 of these crate engines will ever be produced, and then the ZL1 tooling will be retired forever.
Old Aug 22, 2013 | 07:36 PM
01hotrod's Avatar
01hotrod
It's a 4 speed car, the plugs look good and we've went up and back down with the timing. The first pull netted 300 at the tires. I realize it's not as good of a platform and don't know of any pump gas big blocks that impress me with old school heads and no turbo. This is my dad's car and he gave up on the whole hotrodding process 25 or so years ago. This was the first thing he has done an engine swap in a very long time. I just don't want him to be disappointed with it. It is under-performing at this point and we have realistic expectations. I initially said 380rw and had my fingers crossed that it would be higher. GMPP even said it should be around 400 or maybe a tad over at the tires.
Old Aug 22, 2013 | 07:59 PM
gkull's Avatar
gkull
It would take 450 - 475 crank hp to make 380 - 400 RWHP I just don't think that this was the intended outcome of these 427 motors.
But let's look at the happy side. light weight, looks great, and if it comes up 20 hp at breakin those 427 ci put out nice TQ figures and it wiil be fun to drive.
Old Aug 22, 2013 | 09:08 PM
mvette76's Avatar
mvette76
my dad has the cast iron block version zz427 and it made 488/480 on and engine dyno
Old Aug 22, 2013 | 09:16 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
What sort of spark timing are you running? Curious what size carb you're running also.
Old Aug 23, 2013 | 07:05 AM
01hotrod's Avatar
01hotrod
What driveline % loss do you have in mind? 20%? It's a manual transmission.
Old Aug 23, 2013 | 07:34 AM
gkull's Avatar
gkull
The top numbers of mine were just mental approximations. I did not take a calculator to figure out exact numbers. You said GM was throwing around RWHP numbers of 380 - 400. I said that would take 450 - 475 crank HP. So here is the math with a 15 % loss manual tranny.
475 X .15 = 71.25 slightly over 400 RWHP
450 x .15 = 67.5 slightly over 380 RWHP
Kind of like asking you what carb size? When I already posted the GM quoted engine specs of 870 carb. Or where you said that the dyno people tried different timing and when they found the best timing the power came up from 300 to 338. It is amazing to me how little people listen or comprehend when you tell them something.
Old Aug 23, 2013 | 08:51 AM
01hotrod's Avatar
01hotrod
I didn't know what it should make, because gm is unclear esp with the whole rated 430 but closer to 500 bit. Just really looking for someone else to chime in with some evidence.
Old Aug 23, 2013 | 12:36 PM
Corey_68's Avatar
Corey_68
in my experience with chassis dynos, 25% losses with a TH400/TH350 and 20% lost with a 4speed. Only modern 5 or 6speed manuals see 15% loss.
Old Aug 23, 2013 | 01:28 PM
ryanmh's Avatar
ryanmh
I recall reading, once upon a time, that this "grossly underrated" claim was really just urban folklore. What raises my eyebrows here are the cylinder heads: Your description says these use oval ports. IIRC, ZL1s used big rectangle port heads. That, and as already noted, the compression ratio is way down from the original ZL1, which was not (and is not) really a streetable motor. I don't think it's fair to assume this motor will necessarily perform even as well as the original. The roller cam is a nice update, but the rest of the package may very well not make up for it. I wouldn't be surprised if those RWHP numbers are about right for an automatic.
Old Aug 23, 2013 | 03:25 PM
glen242's Avatar
glen242
I find it interesting that GM never quoted RWHP, but a crate engine seller does.
01hotrod, can you provide a link or at least a web site to the company you are dealing with?
Old Aug 23, 2013 | 04:37 PM
ddawson's Avatar
ddawson
So you have a GM rated 430HP crate motor and got 338 RWHP?
I'd say you are not that far off.
Old Aug 23, 2013 | 06:23 PM
01hotrod's Avatar
01hotrod
What I had asked for was tangible evidence from an actual install of this engine. I'm not bitching, just wanted to know what we should be able to expect.
Old Aug 23, 2013 | 06:33 PM
69427's Avatar
69427
Is there a reason you're hesitant to answer my question concerning your timing specs?
Old Aug 23, 2013 | 08:39 PM
gkull's Avatar
gkull
Part of the problem on getting an answer is that only 427 of these motors are going to be built and at the @ $25,000 price tag it is not something the general population of hot rodders would even invest in.
The ZZ427 with 480 hp is 1/2 the price for a 200# maybe weight penalty. It specs with a bigger H-roller cam and maybe bigger aluminum heads.
I was maybe even low balling the 15% drive train loss.
IMO - you bought a very nice low production motor not made for performance. Maybe call them up and say you got duped and get one of the many higher hp crate motors. But these rare motors are just bought by so few people that it would be hard to get a comparison.
Old Jan 5, 2022 | 08:19 PM
MagnumC3's Avatar
MagnumC3
Default Block Casting Numbers
I know this is a very old post but Does anyone know the block casting number range for the anniversary 427? I am looking at buying one but the seller has no proof its a anniversary 427. The casting number is 3946058.
Old Jan 7, 2022 | 02:06 PM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
FYI, it's not a good idea to resurrect old threads, better to start a new one so it gets the right attention and the exact answer you need
To Anniversary 427 install questions
