zz4 in a 72........
marco here, i'm considering attemping an engine change in my 72 that I inherited when Dad passed away. The ZZ4 looks really cool, especially the turnkey option. also planning to get the bowtie 200R4 to go with it.......I spent quite a bit of time with the search engine but didn't come up with the info i'm looking for.
first off, car is stock(restored), power steering, ac, power brakes ( I added this with y'alls help), and point dizzy w/tach drive.
with the turnkey option does the drive system fit and work or are changes needed.
it looks like the turnkey comes with an ac compressor, I already have one and don't want to convert to 134, so will mine work, or are the heads not drilled for it.
I looked to see if anyone posted up doing this job and listing what they did to make it happen, but didn't have any luck. anyone got the lowdown for me? thanks much!!
m
what exhaust changes are needed?
I changed to a zz4 last year and love it. Still have a TH-400 so I know I'm losing a lot of HP in the tranny and with a three speed, I don't get the OD gear, which I would like at some point.
Can't help you on the AC question. My AC is putting the top down.
I would suggest calling and asking your questions to GM Performance. I know the heads already come pre-tapped for all the holes you need to mount brackets for AC/Alt, etc.
Here is a pretty good write-up on the swap. http://corvettec3.ca/zz4.htm
PM me if you want to discuss various aspects of the swap, as I may not spot this thread again....
Otherwise, it's as close to a perfect fit as you can get.
second, sorry it took so long to get back to the thread,
so far it looks like that if i order the engine with the short shaft water pump, all my accessories will bolt up and work, my exhaust manifolds and pipes will bolt up and work(stock rams horn manifolds and true dual 2'' i think, need to 2bl check that), what i am not hearing is will the weight difference in the engine cause front ride height issues, what year electric tach do i have to get , since the turnkey comes with the hei and the carb and intake, and is there anything else???
it looks like the bowtie level 2 is the way to go and i need to figure out how to mod the shifter to get first gear,,,input???
and as always, thanks again!!!!!!!!!!!!!!!
marco
thanks
marco
Everything bolted up as it should. However, I did NOT go back in with the a/c compressor, but was told it would bolt up..Good luck, you will love it.
see it here :
Enviro-Safe™ Refrigerant
I have about 9000 trouble free miles on it, in about 3 yrs.
That being said, I have a 500hp/500tq 383 ready to go in, so I will be selling the ZZ4.
Interested? or if you have any questions about the combo, install, etc, shoot me a PM.
thanks
marco
When your orig motor is in storage it will need ocasional attention. You'll want to turn the crank every few months to keep some valve springs from being compressed for the time its bagged up.
There are probably some other things you may want to do also... I'm sure some folks will chime in.
marco
I used the ZZ4 in my wife's 78 S/A. It bolted right in. It is a really nice motor but for a couple of extra bucks I would have gone with the 383. I really like the 58cc aluminum heads on the ZZ4 but if I had to do it again, I would take the 383. For the buck you can't really go wrong with either....
