cheapest 383 rotating kit
Old Aug 23, 2013 | 12:33 PM
1977L48's Avatar
1977L48
Default cheapest 383 rotating kit
what is the cheapest kit, idk if it would be cheaper buying a crank, rods, and pistons separately? I have a 78 3970010 block that it will be going into, and I would prefer an internal balance so I can keep driving my vette until the build is complete so I can reuse the current flywheel
Old Aug 23, 2013 | 12:40 PM
cv67's Avatar
cv67
St. Jude Donor '05
Check Ohio crank or speedmotive.
Know that you may need more clearancing for rods ck the cam also. Sometimes the cheap mismatched kits require more to balance.
Just have to make the calls and do your research.
Old Aug 23, 2013 | 12:46 PM
1977L48's Avatar
1977L48
Im going to have the machine shop build the short block for me so they can degree the cam and make sure everything will work together
Old Aug 23, 2013 | 01:16 PM
MrJlr's Avatar
MrJlr
what are they charging for that ?
Old Aug 23, 2013 | 01:19 PM
1977L48's Avatar
1977L48
im not sure, I just tore down the engine today, when I pulled a head I noticed the NR3 piston was hitting it, pulled the piston and the bearing from the cap of the rod spun between the crank and rod, moving it up, idk if it will be able to be turned or not to correct it, its about a step of the thickness of a dime from where the bearing came to rest. I was just looking at options, everything else looked great, it had 2.02 heads on it, tons of sludge and 103k miles
Old Aug 23, 2013 | 01:35 PM
Scott Marzahl's Avatar
Scott Marzahl
What size combustion chambers do you have? Competition Products has a great pro street kit with 4340 rods, Icon forged pistons for less than $900.
Old Aug 23, 2013 | 01:50 PM
1977L48's Avatar
1977L48
I have an extra set of big valve 882's that i would like to run, so 76cc
Old Aug 23, 2013 | 02:00 PM
TedH's Avatar
TedH
I found fully balanced assemblies with damper and flexplate for $900 on eBay.
Google Searched on "383 Balanced Rotating Assembly 2pc"
Old Aug 23, 2013 | 02:01 PM
Rally68's Avatar
Rally68
I saved an article on my computer some time back from Super Chevy or Chevy Hi Performance about a build they did with a 383 kit from a company called Powerhouse. I can't find it right this second, but if you google it I'm sure it's there
Old Aug 23, 2013 | 02:03 PM
1977L48's Avatar
1977L48
ok, and I have the TKO500 in my vette, so I would like to go with an internal balanced crank
Old Aug 23, 2013 | 02:19 PM
1977L48's Avatar
1977L48
I think powerhouse is going to be the hot ticket, I had forgotten about them but a kit, crank, pistons, rings, rods, balancer, and flywheel is 549$
Old Aug 23, 2013 | 02:26 PM
Scott Marzahl
For internally balanced?
Old Aug 23, 2013 | 02:34 PM
1977L48's Avatar
1977L48
they said they do external, but I have a neutral balanced flywheel so they will use one like it to balance it before its shipped.
Old Aug 23, 2013 | 02:40 PM
TedH's Avatar
TedH
I wondered if Powerhouse was still around. They had the best price several years ago when the 383 conversion popularity really took off.
I see balancing adds $200 to the $550 price. Still a good deal at $750. However, are the parts all name-brand? Hard to tell from the advertisement. That price is also cast pistons. I assume cast 3.75 crank also.
Old Aug 23, 2013 | 02:48 PM
Ibanez540r's Avatar
Ibanez540r
http://www.skipwhiteperformance.com/...roduct=T&Sub=B
http://www.whiteperformance.com/assemblies.html
Old Aug 23, 2013 | 02:57 PM
TedH's Avatar
TedH
I think this is the outfit on eBay as the stock photo and descriptions are nearly identical.
Old Aug 23, 2013 | 08:01 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
You get what you pay for. If it has a balancer and flywheel included it is externally balanced. Fast, Durable, Cheap, pick two.
To cheapest 383 rotating kit
