What Brake Fluid?
Old Jun 30, 2002 | 10:48 PM
Xracer's Avatar
Xracer
Default What Brake Fluid?
Hi All,
I am finally getting to the point of putting the news brakes on the 80. I have a new master cylinder, new brake lines and new Vette Brakes O-ring calipers. Since everything is new what should/could I go with for brake fluid?
Joe
Old Jun 30, 2002 | 10:52 PM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: What Brake Fluid? (Xracer)
DOT4 is common. has a higher boiling point than 3.
Old Jul 1, 2002 | 08:29 AM
mrvette's Avatar
mrvette
X, why in hell use anything but DOT5, 3-4 are basically the same with that water absording charactoristic....in fact I can't figger even why they are on the market, other than planned obsolescence....
GENE
Old Jul 1, 2002 | 09:48 AM
mountainmotor's Avatar
mountainmotor
For what it is worth I use Castrol LMA "Low Moisture Activity" it exceeds DOT 4 Specs and has a very high boiling point.
Old Jul 1, 2002 | 09:57 AM
mrvette's Avatar
mrvette
Default Re: What Brake Fluid? (mountainmotor)
Mountainmotor, you mean someone finally addressed the issues with dot3-4 fluids??? jeez been my entire automotive life and much more, and they FINALLY got it right??? took long enough....
only thing I ever knew about was dot5 as a cure for rusty brakes...
matter of fact, it's been well known that using say power steering oils or STF would destroy the brake seals in short order....well my thoughts for decades go to making seals that will take the ATF....what the hell, it's done for transmissions O ring seals, just use that compound for the brake seals and fill er up with ATF and have done with it.....
I don't understand why my solutiion there wouldn't work.....any smart brake guys out there???
seems it should even work with ABS systems which dot5 supposedly will not....
afterall, ATF causes no foaming problems with a tranny pump and torqueconverters, and tons of valves switching back and forth constantly...
all they ever needed to do was change the damn rubber compounds to same as a tranny.....yet we keep using that damn dot3-4 garbage....what gives???
GENE
[Modified by mrvette, 8:03 AM 7/1/2002]
Old Jul 1, 2002 | 01:33 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
If your looking for a good racing brake fluid, I recommend the FORD High Performance brake fluid. Suppose to be VERY good in this environment and I haven't had any problems running it on the street :) .
Old Jul 1, 2002 | 04:15 PM
Wrecked82's Avatar
Wrecked82
I'm with Mountainmotor. Castrol GTLMA - actually Low Moisture Absorption.
Old Jul 1, 2002 | 04:30 PM
Fevre's Avatar
Fevre
Default Re: What Brake Fluid? (Larry82)
Do they make different colored brake fluid so you can tell when you have bleed all the old stuff out? If not can you mix in some type of coloring? Seems that would make it a whole lot easier and less waste. Was thinking food coloring but that is water base and that would be a no no.
To What Brake Fluid?
