Alternator charging question
Old Aug 23, 2013 | 06:46 PM
sircampsalot2's Avatar
sircampsalot2
Default Alternator charging question
I just installed a New Alternator and Battery in my 82 because my battery kept going dead and would not charge. The problem is it still wont charge after the new alt and Batt. any ideas of what could be causing this? I'm lost....thanks for any help
Old Aug 23, 2013 | 08:37 PM
'75's Avatar
'75
First turn the key on and use a test light, see if you have power on all 3 terminals at the alternator.
Old Aug 23, 2013 | 08:57 PM
dpw21562's Avatar
dpw21562
Default Alternator
What size alternator, make sure it meets your demand for current? I just went through a similar deal.
Old Aug 25, 2013 | 07:20 PM
sircampsalot2
which terminals? it has a wire that goes to the back of the alt and then a two wire plug that connects to the side and then one yellow wire. Should every wire going to it be hot? thanks
Old Aug 25, 2013 | 07:29 PM
CMEPASS's Avatar
CMEPASS
Are you sure the one you installed is good. I say that because I have bought replacement alt before and they were bad right from the get go. Do you have a multimeter or a battery tester so you can see what voltage at the battery while it is running?
Old Aug 25, 2013 | 08:15 PM
'75's Avatar
'75
Where is the yellow connected?
Old Aug 25, 2013 | 11:06 PM
my 76 ray's Avatar
my 76 ray
I had that problem until I replaced the connectors on all the wires. You can buy a pigtail for the two wire connector.
To Alternator charging question
