Transmission change
Old Aug 23, 2013 | 08:00 PM
kanvasman's Avatar
kanvasman
Default Transmission change
I have a 78 with a tired 350 engine & 350 auto trans. I am starting to build up a new engine, maybe get close to 350-400 hp tops, plan on a regualr driver, even doing some long distance trips. Wife wants to keep the auto trans, so the question is what would be a good replacement, maybe with an overdrive to boost mpg, without having to add all kinds of electronics and /or driveshaft mods. I'm even open to keeping the TH350, just looking for some options to look into. Thx.
Old Aug 24, 2013 | 12:03 AM
cagotzmann's Avatar
cagotzmann
I am been looking also for a good Trans for my 1978. I would love to have a 5 or 6 speed auto, but the only thing I could find are 4 speed TH200r etc. Similar 1-3 gears and over drive 4th for highway. Needs mods to work. I think I am now moving to a manual 5 speed from Keisler Engineering. RS500 kit which includes everything needed. Cost $5100.00 This gives me 4 gears to replace the TH350 3 plus 1 overdrive. This may be my winter project. If you do find something other than the 4 speeds let me know, I still can change my mind.
Old Aug 24, 2013 | 12:23 AM
Ibanez540r's Avatar
Ibanez540r
The only OD options you have are the 700r4 and 200-4r. The 2004r is an easier swap as it is nearly identical in dimensions as the TH350. You can use your original driveshaft. The 700r4 is longer and the shaft needs shortened as well as mount modified.
The 200 has a first gear of 2.74 compared to the 2.52 of the 350. So an increase in acceleration. The 700 has a steep 3.06 which can be too much depending on what rear end you have. The 200 has a .67 overdrive, slightly lower then the .70 of the 700.
There are quite a few write ups on the conversion here on the forum if you look. Typically the 200 is the way to go. They do get pricey when required to handle higher then stock HP & TQ.
Old Aug 24, 2013 | 12:28 AM
briankeery's Avatar
briankeery
Bought a 200 at the start of summer, will be gathering parts over winter for the swap.
Old Aug 24, 2013 | 12:44 AM
mac79vette's Avatar
mac79vette
My 79 Vette had a TH350 but I had changed it out to a Richmond super T-10 about 6 years ago. I love the manual, but I plan on going to a 5 speed with a over drive, most likely a tremec tko 600.
I did a th 350 to 700r4 in a 71 C-10 truck back in 1997 and it was the best mod ever to that truck. 250,000 miles and still works and the truck runs low 13 sec quarter miles and gets 17 mpg. it would be a very easy swap. What gears do you have? If you have 3.55 gears that will work well with the 700, but if you have high gears like 3.07 than it may be too low a rpm for the engine depending on your set up.
Old Aug 24, 2013 | 06:51 AM
kanvasman's Avatar
kanvasman
Thanks for the input. I'll be crawling under the car and confirm the rear gear ratio and will start looking around at the 200. Will also do some more searches. For my needs, a lot of driving, I would give up some HP for an overdrive if that's what the 200 calls for. Thanks for help in going the right direction.
Old Aug 24, 2013 | 08:59 AM
oldalaskaman's Avatar
oldalaskaman
I bought a Craigslist 2004R ,rebuilt it , added a bunch of reliability/hy-po parts, best upgrade next to the borg. Easiest auto to rebuild, plenty of info on line, no special tools needed except for feeler gauges. But, for the money spent and the time involved, could have bought one already done and been driving sooner. The two costs going either way were pretty much the same, the only difference was the time involved . If you've never rebuilt an auto and would like to learn, its the one to do it with. hope this helps
Old Aug 24, 2013 | 05:43 PM
kanvasman's Avatar
kanvasman
Thanks OldAlaska. Pretty sure I am going in the 200r direction, already looking on cl. i've never done an auto before, and I'm going to study up on what is involved. When I get to that chapter in my build I probably will be in touch.
Old Aug 24, 2013 | 05:59 PM
mrvette's Avatar
mrvette
On the core you use, the one I had came from a 80's 305-350 Elky....
and so you need to know that you get a CORE without any extensive trash in the pan.....MY trans was fairly clean, and no metal in the pan....so it rebuilt easy as pie.....but I did spend almost a week on it, on/off, just a project....
tried to help a friend here, do one, he got a core that was full of trash, steel/aluminum, crap in the pan....
and it gave us nothing but trouble...3rd time around he took it to a shop....and so last I heard he was ok with it.....got transferred to Norfolk and so far outta town.....so outta contact....
Old Aug 26, 2013 | 06:50 AM
donnie1956's Avatar
donnie1956
Easy swap. Installed on in my 78 during my first restro mode. Recently adapted the 2004R to work with my LS swap. No change to crossmember or driveshaft. I did get the shifter adapter from Shiftworks.
Old Feb 23, 2019 | 01:15 PM
arktraveler's Avatar
arktraveler
I’m in the same position with my 81. Original 350 and 3 speed transmission. I hear the 400 and 700r4 trannies bolt right in and both have a low 4th gear that will boost your mpg.
Old Feb 23, 2019 | 01:20 PM
arktraveler
Ibanez is absolutely right on the mark. I had mentioned a 400r but had my numbers wrong. The 2004r is what I meant. Here is a link that explains it nicely:
https://www.hemmings.com/magazine/hm...s/3694151.html
Old Feb 24, 2019 | 09:19 AM
Street Rat's Avatar
Street Rat
I purchased a built 200 4R from Art Carr at California Performance Transmission. I have a 3:54 rear gear in the '81. I love the way this transmission upshifts under power. I can get out on the 80 mph tollway now and cruise.
The BEST part? The installation was a breeze! I purchased a new aftermarket transmission crossmember and everything fell into place. The friend that I had helping me is a Pontiac man. He couldn't believe how easy the swap was.
Craig
Whoops! Old thread.
Old Feb 24, 2019 | 09:22 AM
kanvasman's Avatar
kanvasman
As said above, the 200R4 was a piece of cake install. Didn't have to change anything except put an extra detent in the shifter for the extra gear. FYI, if you are putting a cooler in for the trans, it gets a little tight on that side near the floor. Get it all figured out ahead, OR some guys just cut a hole in the floor near where the fittings will go. Easy upgrade for my '78. Good luck.
Old Feb 25, 2019 | 10:35 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Yo No0b - It's not polite to resurrect old threads. Best way is to ask your question or state your problem and just provide a link to the old thread.
Old Feb 26, 2019 | 11:45 PM
arktraveler
Ratflinger,
I may be a noob at this forum stuff, but it would be because of my age, not my intelligence. You young kids may be good at this stuff but I’m not. I spent all my time being shot, knived and beaten while wearing a badge and serving and protecting. So you might want to show a little respect for I didn’t mean to resurrect an old thread. There are no written rules that would tell me these things.
So I apologize if I’ve offended anyone.
Old Feb 27, 2019 | 05:32 AM
kanvasman's Avatar
kanvasman
No offense here. I am an old guy, and I haven't read all these old threads and the questions they raise so I look forward to any NEW information I can come across. I have even reached out to people who posted in those OLD threads to ask follow up questions and most of them are more than happy to reply. Eventually anything old becomes new again. I have some disco shoes and paisley ties in my closet just waiting....and waiting..
To Transmission change
Old Feb 27, 2019 | 09:27 PM
arktraveler
I’m on this forum and thread needing the same thing. Tips and information.
Now the disco and paisley...... well let’s just say I’m playing Boston and Styx in my old vette.
Old Feb 28, 2019 | 06:19 AM
Street Rat's Avatar
Street Rat
Old Mar 2, 2019 | 09:36 AM
Krystal's Avatar
Krystal
If you're older Corvette is a Daily driver I could see going to the overdrive Transmission.......but you really should seriously consider how you'll use the car.
I put a 450HP 383 in my car two years ago. The Turbo 350 lasted all of 200 miles or so under the far more serious torque before blowing away 3rd gear.
I gave an over-drive trans serious consideration but ultimately came to the conclusion that I'd be better served by a TCI Super Street Fighter Turbo 350. My car is driven too few miles each year to justify the expense and problems that come with a conversion to a 4 speed auto that is as strong. I might have chosen differently though if I did a lot of miles on the highway each year....but at this point my old C3 is a car that only sees 1,000 miles or less per year.....and virtually none of it is highway cruising.
